What Is the Minimal Speed for a Car on a Banked Road?
  • Thread starter Thread starter Skynt
    Speed
The discussion centers on determining the minimal speed required for a car to navigate a banked road without falling off. The initial equation provided relates centripetal force and frictional forces acting on the car. The user has successfully derived the maximum speed but struggles to calculate the minimum speed, expressing confusion over the visual representation of the forces involved. They mention a discrepancy in their calculations, where they expect a result around 8 m/s but are getting 44 m/s instead. Clarification is sought on how to correctly account for the forces to find the minimal speed below the maximum of 16.1 m/s.
Skynt
Basically, we were told that from (mv^2/r)(cos \theta) = \mu[(mv^2)/r) sin \theta + (mg cos \theta)] + mg sin\theta
you could rearrange for the max speed of a car going in a circular path on a banked road at a \theta angle. From that equation above, I derived v max, but now I need to get v minimal. I really don't even understand the visual concept of the equation above - I drew a free-body diagram but I still don't understand it.
Could someone help me figure out the minimal speed the car has to go without falling off?
Also in the equation, he substituted a variable N for normal force with the equation in the bracket. So it's basically
(mv^2/r)(cos \theta) = [\muN + (mg cos \theta)] + mg sin\theta
Can anyone help me with this?
Well, it's been a few days, so... *BUMP* :)
I can't get credit for the answer, but I am still curious as to what it is.
I think it's the speed of the car, which will provide a centripetal force, which is equal in magnitude to the x component of the normal/support force.
No, I don't think that works. I'm suppose to get the result 8. something
But instead I get 44 with that solution.
The max speed was 16.1 m/s, which means the minimal speed needs to be under that.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
