Finding the order of a factor group
  • Thread starter Thread starter PsychonautQQ
    Group
PsychonautQQ
G is a cyclic group generated by a, G = <a>. |a| = 24, let K=<a^12>.
Q: In G/K, find the order of the element Ka^5
Work:
K=<a^12> = <1,a^12> --> |K| = 2
|G/K| = |G| / |K| = 24 / 2 = 12,
so |Ka^5| = 1,2,3,4,6 or 12.
now I'm lost ;-/
If we let ##n## denote the order of ##Ka^5##, then what can you say about ##(Ka^5)^n##?
(Ka^5)^n = 1? or perhaps (Ka^5)^n = K?
Ka^5 = {a^5, a^17}
(Ka^5)^12 = {a^120, a^204} = {a^12,1} = K
so... (Ka^5)^12 = K
12 is the order.
How come sometimes order means number of elements in a group?? Ka^5 has the same number of elements as K since you can go from one to the other with a bijection right? or does Ka^5 even have elements? does it have more elements than K?
##(Ka^5)^n## is equal to the identity element of ##G/K##, which is ##K##.
Ka^5 = {a^5, a^17}
so... (Ka^5)^12 = K
12 is the order.
Yes, this is correct. As you said in your first post, the only possibilities for ##o(Ka^5)## are 1,2,3,4,6 or 12. So to rule out the numbers smaller than 12, just verify that ##(Ka^5)^m \neq K## if ##m## is 1,2,3,4, or 6. You can do this easily by recognizing that ##(Ka^5)^m = Ka^{5m}##, and that ##Ka^{5m} = K## if and only if ##a^{5m} \in K##, if and only if ##5m## is an integer multiple of 12.
Yes, the word "order" is used in a couple of different but related ways. Usually it should be clear from the context which one is meant:
  • Order of a group ##G## = the number of elements contained in ##G##. Usually we use the notation ##|G|##.
  • Order of an element ##g## = the number of elements in ##\langle g\rangle## (the subgroup generated by ##g##) = the smallest positive ##n## for which ##g^n = 1##. Usually we use the notation ##o(g)## or ##|\langle g\rangle|##. It is better not to write ##|g|## because it creates an ambiguity if ##g## is a coset: should ##|g|## mean the number of elements in the coset, or the order of the cyclic group generated by the coset?
Correct, ##Ka^5## is a coset of ##K##, and all cosets of ##K## have the same size, by Lagrange's theorem. But the problem is asking for the order of the element ##Ka^5## in the group ##G/K##. In other words, what is the smallest positive ##n## such that ##(Ka^5)^n = K##? Just as you answered above.
Sure, it has elements, the same number as ##K## has. If ##K = \{k_1, k_2, \ldots, k_n\}## then ##Ka^5 = \{k_1a^5, k_2a^5, \ldots k_na^5\}##.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
