Finding the output impedance of Current Controlled Current Source
The discussion revolves around deriving the output impedance of a Current Controlled Current Source (ICIS) circuit. Participants explore various methods and assumptions related to the calculation of output impedance, including the treatment of input and output currents, and the implications of negative feedback on impedance values.
  • One participant expresses confusion over their derived output impedance equation not matching the textbook, suggesting that negative feedback should increase output impedance.
  • Another participant asserts that I2 cannot be zero, questioning the implications of this assumption on the analysis.
  • Several participants discuss the relationship between input current (Iin) and I2, with one stating that Iin should be set to zero when calculating output impedance.
  • A participant proposes a method involving applying a test voltage to find output impedance but notes potential contradictions in their equations.
  • There is a suggestion that the circuit is misidentified as a TIA rather than an ICIS, which affects the interpretation of output variables.
  • One participant provides a Mathematica code snippet to derive output impedance, indicating that their result aligns with another participant's but in a different form.
  • Another participant emphasizes the importance of considering the quiescent operating point and suggests a derivative approach to calculate output impedance.
Participants express differing views on the treatment of currents and the correct approach to calculating output impedance. There is no consensus on the correct method or the implications of certain assumptions, indicating ongoing debate and exploration of the topic.
Participants highlight potential misunderstandings regarding circuit identification and the treatment of various currents in the analysis, which may affect the derived equations and conclusions.
paulmdrdo
Summary:: I was trying to derive the equation for the output impedance of the ICIS circuit.
Here's what I've tried so far.
What I have derived does not agree with the one provided in my book.
Since it is a current source the negative feedback must increase the output impedance. The one I derived says otherwise. Can you tell me what I am missing? TIA!
I2 cannot be zero. Why not? :smile:
I assumed that the input impedance Rin of the opamp is so large. I2 is very small to have an effect.
What do you think the relationship is between Iin and I2?
I did not include Iin because I learned that when you are finding the output impedance of an amplifier all sources must be set to zero. Short circuit for voltage sources and open circuit for current sources. That is Why I2 is zero. Have I misunderstood something?
Here are the steps I was taught to go about finding Zo
turn off all sources
Apply a test voltage at the output
Find Ix. Then Zo = Vx/Ix
Opening the input and using a test voltage on the output is often a way to go but it won't work here. To see why: with the input open, assume Vx!=0. then write your equations and you should find a contradiction. (you didn't because I think you have a couple of sign errors but the IL equation is definitely wrong) You can try the alternative, use a text Ix and find the corresponding Vx, but this should lead Zo=0, which is also not correct.
Your teacher should've taught you another way which is also common.
Does anyone know what the ICIS acronym means? I would've called this a TIA with T-feedback. I googled it and ICIS seems like it is a notation from Chegg's text which I never used.
ICIS stands for Current(I)Controlled Current(I) Source.
What's wrong with the equation of IL?
Actually, I am wrong. Your technique will work but the math is a bit harder that way which is why I didn't think do to it like that. You didn't get the correct answer because your initial set of equations has a few mistakes. Specifically look at the node that joins R1, R2 and RL (the voltage is not zero at that net) and note that the opamp is wired as an inverting amplifier.
Yes. It is not zero. That is why I have the expression of the voltage at that node.
Let's label that node Va. If we agree that Va is non-zero then how can IL=Vx/(RL+R1)?
By KVL.
Oh right. I forgot we're using I2=0 so that works. I did KCL at that node which gives a slightly different set of equations. I think your answer is right it's just in a different form than the book's.
What does your book say A_vol is?
I solved it in mathematica with this line of code.
Zo=Simplify[Vx/Ix /.
Solve[{Va/R1 == (Vx - Va)/RL,
Ix == (Vx - (-A*Va))/Ro + (Vx - Va)/RL}, {Vx, Ix}]]
The answer was this. Which is the same as yours but rearranged.
{((R1 + RL) Ro)/(R1 + A R1 + RL + Ro)}
I just realized where we both messed up. We both ignored the labels on the initial problem. I am still assuming the circuit is a TIA but it's not. It's a current controlled current source. The output variable is the current through RL, not the output voltage of the opamp like in a TIA. If you connect a test source to the right output then you'll get the correct answer.
Well for one thing, Iin is not a source affecting the output impedance directly. And when you set it to zero, you lose information about some of the currents and voltages in the output circuit.
Maybe this problem can be worked other ways, but I would solve the output circuit for the quiescent operating point given some load impedance, and use the following equation to calculate the output impedance (your output port is across R1, correct?):
[tex]Z_o = \frac{dV_o}{dI_o}[/tex]
I got tricked by the circuit diagram too. I kept thinking it was a TIA.
The ICIS note in the upper corner means it's a current controlled current source and the output label is given as the current through RL. Because it's a current source the question wants the Norton resistance, not Thevenin. The text is doing the derivative technique but it's hidden because the quiescent is zero everywhere. The technique is add Ix in parallel with RL and look at the corresponding change in differential voltage on RL, this is Vx.
Zo=(Vx-0)/(Ix-0)=Vx/Ix and one gets the answer from the book.
  • · Replies 29 ·
