Finding the Right Module for Spur Gears
  • Thread starter Thread starter alphaomega@ho
    Gears module
When calculating the module for spur gears, it's important to refer to the DIN 780 standard table for guidance. The discussion emphasizes rounding up calculated module values, such as 3.91 to 4, and rounding down when appropriate, like 3.45 to 3. This approach ensures that the chosen module aligns with standard sizes. Participants confirm that rounding is a common practice in gear design. Properly selecting the module is crucial for gear compatibility and performance.
alphaomega@ho
hello,
i am doing gear calculations
my problem: i get several point numbers for the module of the spur gear
din 780 suggest a standard table with modules
so i just have to wrap up my calculated modules, for example: 3.91 => 4 ?
thank you vm !
anyway can help me ?
someone, please ?
Yes - round up
oke thank you !
always round up or 3.45 => 3 ?
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
