Finding the slop of a string (Waves)
  • Thread starter Thread starter cse63146
    String Waves
To find the slope of a transverse wave described by the equation y(x,t) = Asin(kx - ωt), the derivative dy(x,t)/dx must be calculated. The correct approach involves applying the chain rule, treating x as the variable and t as a constant. The derivative yields dy(x,t)/dx = A*cos(kx - ωt) * k, indicating that the term involving ωt should not be included in the derivative. The discussion emphasizes the importance of correctly identifying variables and constants when differentiating wave equations.
cse63146
Wave motion is characterized by two velocities: the velocity with which the wave moves in the medium (e.g., air or a string) and the velocity of the medium (the air or the string itself).
Consider a transverse wave traveling in a string. The mathematical form of the wave is
y(x,t) = Asin(kx - \omega t)
Find the slope of the string \frac{dy(x,t)}{dx} as a function of position x and time t.
So to find the slope of that equation, I would just need to take it's derivative. x is the variables, and \omega, A, t are constants. I would also need to use the chain rule when doing the derivative of sin.
So I get: \frac{dy(x,t)}{dx} = (Acos(kx - \omega t))*(k - \omega t)
but it says I'm wrong. Any suggestions where I went wrong?
Check your result for consistency of units.
\frac d {dx} ( kx- \omega t) = ?
would I treat the x as a variable and t as a constant?
