Calculating the Sum of n(n+1) Using Even Numbers and Odd Number Sums
  • Thread starter Thread starter MathematicalPhysicist
    Sum
finding the sum of...
1*2+2*3+3*4+...+n(n+1)
i need to find to what it's equal?
i tried doing various ways:
2*(1+3)+4*(3+5)+6(5+7)+...
which means an even number times the sum of two odd numbers
so let's say:
a=2m
b=2m-1
a(b+3)+a(b+5)+a(b+7)...+n(n+1)
ab*n+a(3+5+7...+2n-1)*(n-1)=
a{[bn+(n-1)(3+5+7+...2n-1)]}
when 3+5+7+...(2n-1)=(3+s_n)n/2
when s_n=3+n(2n-1-3)=2n^2-4n+3
so (3+s_n)n/2=(2n^2-4n+6)n/2=n^3-2n^2+3n
here i pretty much given up, can someone help me.
In particular,
\sum_{k=1}^{n} k(k+1) = \frac{n(n+1+1)!}{(1+2)n!} = \frac{n(n+1)(n+2)}{3}
i think you jumped there too quickly, here:
sigma[k=1 to n](k+j)!/(k-1)!=n(n+j+1)!/(j+2)n!
the sigma equals:
(1+j)!/0!+(2+j)/1!+...+(n+j)!/(n-1)!
so where's the thing in between?
The proof ? Oh, just I used Maple :wink: .
so does someone know how to prove it, or should i use my bare hands. (-:
Now that you know the final answer, the result should be easy to prove by mathematical induction.
Also...
This method works! (For an even number of terms.)
<br /> \begin{equation*}<br /> \begin{split}<br /> 1*2 + 2*3 + 3*4 + 4*5 + 5*6 + 6*7 + 7*8 + 8*9 + \cdots &amp;= 2 \left( 1 + 3 \right) + 4 \left( 3 + 5 \right) + 6 \left( 5 + 7 \right) + 8 \left( 7 + 9 \right) + \cdots\\<br /> &amp;= 8 + 32 + 72 + 128 + \cdots\\<br /> &amp;= 8 \left( 1 + 4 + 9 + 16 + \cdots \right)\\<br /> &amp;= 8 \left( 1 + 2^{2} + 3^{2} + 4^{2} + \cdots \right)\\<br /> \end{split}<br /> \end{equation*}<br />
The stuff in the brackets is a known series, but this is not a proof. It does, however, suggest the following more formal method. Let n = 2m, so that
\sum_{k=1}^{2m} k \left( k + 1 \right) = \sum_{k=1}^{2m} a_{k},
where a_{k} = k \left( k + 1 \right). Define a series by b_{1} = a_{1} + a_{2}, b_{2} = a_{3} + a_{4}, etc. In other words, b_{j} = a_{2j - 1} + a_{2j}.
Now,
<br /> \begin{equation*}<br /> \begin{split}<br /> \sum_{k=1}^{2m} k \left( k + 1 \right) &amp;= \sum_{k=1}^{2m} a_{k}\\<br /> &amp;= \sum_{j=1}^{m} b_{j}\\<br /> &amp;= \sum_{j=1}^{m} \left[ a_{2j-1} + a_{2j} \right] .\\<br /> \end{split}<br /> \end{equation*}<br />
What do you get when you sub in for the a's?
Regards,
George
I would think that it would be simpler to write
\begin{equation*}\begin{split}\sum_{k=1}^{n} k \left( k + 1 \right) \\&amp;= \sum_{k=1}^{n}(k^2+ k)\\&amp;= \sum_{k=1}^{n} k^2+ \sum_{k=1}^{n} k\end{split}\end{equation*}
And those two sums are well known.
Yikes! :blushing:
This exemplifies something I often tell people: take care when replacing symbols by numbers, because this sometimes complicates the issue at hand.
Mea culpa.
Regards,
George
thank, i believe this is much easier from what i had thought before.
the first k^2 sum is of what galileo find, and the second one is just plane arithmatic progression.
