Finding the Tension in a Hanging Rope: A Mathematical Approach
The discussion focuses on deriving an expression for the tension in a hanging rope as a function of the distance y from the top. Participants clarify that the weight of the system should be expressed correctly, emphasizing that the mass of the rope below a certain point must be considered. A key point is the relationship between the mass of the rope and its length, leading to the formulation of tension as T = (M + (m(L-y)/L))g. The importance of correctly identifying the distance from the bottom of the rope to the point y is also highlighted. Overall, the conversation aids in understanding how to express tension in terms of the variables provided in the problem.
bmarvs04
A block of mass M hangs from a uniform rope of length L and mass m. Find an expression for the tension in the rope as a function of the distance y measured vertically downward from the top of the rope.
For the System:
W = (m + M)g = T
I summed all the forces in the Y direction to arrive at the equation above, but I don't know how to make it in terms of 'L', or as they state 'y'.
For the System:
W = (m + M)g = T
Your expression for W is incorrect, the units of (M+m)g are units of Force (Newtons), not units of work/energy (Joules). Mathematically, what is the definition of work?
More importantly for this problem, what is the force due to gravity on the rope at the halfway point? Is it really the same as the force at the top of the rope? Why or why not? What fraction of the mass of the string is below the halway point? How about below a distance y below the top?
I'm sorry, I forgot to define my variables. W is the weight of the system, not the work done. And T is the tension of the rope.
Now since the rope is uniform, I know the mass and length have a direct relationship and that the tension will increase when the length (L) is increased.
I still think T = (M + m)g is the right equation if I could just substitute an expression for L in for m. But I am having trouble finding a fraction or what not in order to do so..
That's not really the correct way to do that. In the question, m is defined as the mass of the entire string (A.K.A. a constant)...you could however use a different variable to represent the mass of the string below the point y. For example you could use T=(M+{\mu}(y))g where {\mu(y)} is the mass of the string below the point y...As for finding an expression for {\mu}(y), you know that there will be a linear relationship between {\mu}(y) and y so you can immediately write {\mu}(y)=Ay+B. You then need to determine what the constants A and B are...how much mass is below the point y=0 (i.e. what is {\mu}(0))? How about at the end of the string (i.e. what is {\mu}(L))? Those answers should allow you to easily find A and B.
Ok I think I understand. Would it make sense for T = (M + ((y/L)*m))*g then?
This makes sense to me because 'y/L' would give you the fraction of rope you are working with, then you could multiply it with 'm' to find the mass of the length you are working with.
Not quite, y/L doesn't give you the fraction of the rope you are dealing with, because y is the distance below the top, not the distance above the bottom...so if y is the distance from the top to the point P and the total length is L, what is the distance from the bottom to the point P? This should give you your correct ratio.
So it would be (L-y)/L? I forgot to re-read the problem to see what 'y' was actually measuring.
Thanks for everything.. I really appreciate it.
Yup, now you've got it. And you're welcome.:smile:
