Finding torque (vector cross product)
To find the torque about an axis through the origin perpendicular to the xy plane, the torque is calculated using the cross product of the position vector r = 3i + 2j and the force vector i - 2j, resulting in a torque of -8 k NM. The right-hand rule confirms the negative direction of the torque. For the second part, the torque about an axis at the point (5,5) requires calculating the new position vector from this point to the force application point, leading to a torque of 7 z Nm. The change in direction from negative to positive torque is due to the different reference points used in the calculations. Understanding the relationship between the position vectors and the force application point is crucial for accurate torque determination.
vu10758
A particle position is described by position vector r = 3i + 2j and the force vector i - 2j acts on the object.
1) Find the torque about an axis through the origin and perpendicular to the xy plane. Draw the two vectors to check your torque direction.
I used the right hand rule and found out that the torque will have a negative direction. Then I used cross product term by term.
My torque is -8 k NM.
2) Find the torque about an axis through the point x = 5m, y = 5m perpendicular to the xy plane. Draw the two vectors to check your torque direction. The force should produce a roation about (5,5) consistent with your answer.
How do I do this? The answer is 7 z Nm. Do I find the torque the same way as for part 1, and then somehow take the distance between them into consideration? How come the direction is now positive?
Ok the first question was pretty straightforward, they gave you the position vector from the origin to your force point of application. Now for the 2nd question you have another position. They give you the position vector for the other axis, and you have the position vector for your force point of application. Therefore, you can calculate the new position vector from the new axis position to your force of application. Remember is from the new axis position to your force point of application.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
