Finding V given U (complex variable function)
  • Thread starter Thread starter mancini0
    Function Variable
mancini0
I can't seem to find my mistake when I work through the following problem:
f(z) = u(x,y) + iv(x,y) is holomorphic.
If u = x^2 + y^2, find v.
I realize I must apply Cauchy - Riemann here.
Since f(z) is holomorphic, it is differentiable. Since f is differentiable, its derivative must satisfy the Cauchy-Riemann Equations, that is du/dx = dv/dy and -du/dy = dv/dx.
Since they gave me u, finding the partials of u is easy enough:
du/dx = 2x, du/dy = 2y
So by Cauchy Riemann, dv/dy = 2x.
So if I integrate dv/dy with respect to y, I should get v + a constant, which may be a function of x:
Integral ( dv/dy) dy = Integral of 2x dy = 2xy + F(x)
So v = 2xy +F(x)
Then dv / dx = 2y + F'(x) which should equal -du/dy by Cauchy Riemann.
so 2y + F'(x) = -2y
Then F'(x) = -4y
Integrating F'(x) with respect to x gives F(x) = -4xy + c (my gut says I made my mistake here)
So v = 2xy -4xy
Check:
dx/dv = -2x
dy/dv = -2y
which do not satisfy the Cauchy Riemann Equations... so I did something wrong...
There's something very wrong here. x^2+y^2 isn't an harmonic function. It's laplacian isn't zero. It can't be the real part of an holomorphic function. This may explain your problem. Is there a typo? Did they mean x^2-y^2?
No, I'm certain that u = x^2 + y^2.
So if I'm not mistaken, a harmonic function has 2nd order partial derivatives that sum to zero.
Uxx + Vyy = 0.
Why does this imply the function doesn't have a real part? We do not study harmonic functions until later.
Thanks,
Mike
If you take the x derivative of ux=vy you get uxx=vyx. Then take the y derivative of uy=(-vx). Get uyy=(-vxy). Now if you add the two and remember that vxy=vyx you get uxx+uyy=0. If that laplace equation isn't true then f(z) can't be holomorphic no matter what you pick for v(x,y).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
