Finding vector coordinates help
nokia8650
My question is regarding the following problem:
Relative to a fixed origin, O, the line l has the equation
r = (i + pj − 5k) + λ(3i − j + qk),
where p and q are constants and λ is a scalar parameter.
Given that the point A with coordinates (−5, 9, −9) lies on l,
(a) find the values of p and q,
(b) show that the point B with coordinates (25, −1, 11) also lies on l.
The point C lies on l and is such that OC is perpendicular to l.
(c) Find the coordinates of C.
(d) Find the ratio AC : CB I have no problem with parts a to c (for a the answer is p=7, q=2, and for c the answer is (4, 6, −3)). However, for part (d) the method which I used was simply finding the magnitude of AC and CB, and then finding the ratio. However, the markscheme has used a far more elegant method, which I was wondering if someone could explain:
A : λ = −2, B : λ = 8, C : λ = 1 ∴ AC : CB = 3 : 7
Thank you for any assistance.
I take it you mean that in parts (a), (b), and (c), you have determined that the corresponding \lambda values for A, B, and C are -2, 8, and 1 respectively.
Write the equation of the line as P+ tQ. Then A= P-2Q, B= P+ 8Q, C= P+ Q. A-C is the vector (-2-(1))Q= -3Q and B- C is the vector (8- 1)Q= 7Q. Since the lengths AC and BC are 3|Q| and 7|Q| respectively the ratio of their lengths is 3/7.
ahh yes, of course! Thank you!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
