Finding Vector Fields that Satisfy Certain Curls
EngageEngage
Is it possible to find a vector field whose curl is yi? xi?
I found that if F = <0,0,y^2/2>, its curl will be yi. However, I cannot figure out a vector field whose curl will be xi. I tried using exponentials and just different combination of x's, y's and z's as components of F, and just building my function as I go through the 'curl determinant', but haven't been able to find anything. If someone could please help me out that would be greatly appreciated. Thank you
Take the divergence of the vector field you're interested. If it's zero, then you can find the "vector potential" for the vector field you're interested in (for more info, see http://en.wikipedia.org/wiki/Vector_potential).
Since the divergence of xi is 1, you cannot find a vector field whose curl is xi.
Hope that helps!
Thanks for the help!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
