Finding Vector Lengths: Can't figure out what I am doing wrong
  • Thread starter Thread starter lanzjohn
    Figure Vector
The discussion revolves around calculating the y-component of vector B given vector A and their respective angles. The user initially calculated the y-component using trigonometric functions but was uncertain about the sign of the result. It was clarified that since vector B points downward, its y-component should indeed be negative. Additionally, the importance of considering vector direction after calculating lengths was emphasized, noting that reversing directions would not change the triangle's dimensions. Ultimately, the correct approach involves both accurate calculations and attention to vector orientation.
lanzjohn
The diagram below shows two vectors, A and B, and their angles relative to the coordinate axes as indicated.
DATA: alpha = 42.7 degrees,
beta = 60.0 degrees,
A = 6.70 cm.
The vector A - B is parallel to the -x axis (points due West). Calculate the y component of vector B.
SOH CAH TOA
So I can't figure out what I am doing wrong. I thought I knew these basics! ARG Anyway I got one chance left. So please let me know if I'm right
Well I found the angle of the triangle I am trying to find vecor y for. I am using the right triangle Since the sum vector (A-B) has no y-component, vector A must have the same y-component as vector B.
So:
90-42.7=47.3
cos47.3 = x/6.7
6.7 * cos47.3=x
Answer:
x=4.54367 cm
And that's it! BUT NOOOOO its not right ha. Is it suppose to be -4.54367cm because the component y is going y-? Or maybe I am just pig headed and am missing a major part in the problem.
Yes, that's my guess. The y-component of vector B is point down, so that component is negative.
If you solve this problem using triangles (which is perfectly okay to do), you need to go back later and look at the vector to keep track of the directions of the components. Hypothetically, if A and/or B reversed directions (180o), you would still end up with the same triangles. The lengths of the sides of the triangles involved would be identical to the case where directions were not reversed. So after you calculate the lengths of a given side, you need to go back and look at the vector to determine which way that side is pointing.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
