Finding Velocity via Convervation of Energy
  • Thread starter Thread starter Norngpinky
    Energy Velocity
The discussion focuses on calculating the speed of a projectile when it strikes the ground using the conservation of energy principle. The projectile is launched from a cliff at an angle of 25 degrees with an initial velocity of 195 m/s from a height of 315 m. The correct approach involves equating the initial energy, which is calculated using the formula 0.5 * m * (195^2), to the final energy, represented as 0.5 * m * (final velocity^2). The mass cancels out, and the final velocity is determined to be approximately 114 m/s, highlighting the importance of using the correct initial velocity without decomposing it into components for this energy-based problem.
  • Understanding of conservation of energy principles in physics
  • Familiarity with projectile motion concepts
  • Knowledge of basic kinematic equations
  • Ability to manipulate algebraic equations
  • Study the conservation of mechanical energy in various contexts
  • Learn about energy transformations in projectile motion
  • Explore the implications of launching angles on projectile trajectories
  • Review kinematic equations and their applications in energy problems
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators seeking to clarify concepts related to projectile motion and energy calculations.
Norngpinky
A projectile is shot upward from the top of a cliff in an angle of 25 with a velocity of 195 m/s.The height of the cliff is 315m. What will be its speed when it strikes the ground below? (Use conservation of energy)
Ok...initial energy = final energy
Initial energy = .5m*(initial velocity square) + mgy
Final energy = .5m*(final velocity square)
initial velocity = sin*theta*upward initial velocity = sin25*195
So I set them to equal and I got final V to be 114, but it says I had it wrong, canceling out the mass... I have no clue what I did wrong there...
should not be used in this one. It is an energy problem, not a 2D motion analysis. Just use the 195 in the first 1/2m*v^2.
OK, thank you! =)
  • · Replies 56 ·
