Finding volumes by rotating around an axis of revolution
Sidthewall
1. Homework Statement
k so here is the equation i need help with that will find me the volume of a sphere
2*pi*y*sqrt(25-(y-1)^2) dy - 5*pi from 0 to 6
the 5 pi is the volume of a cylinder
2. Steps
so first i subbed u=y-1
took the 2 pi out of the integral
that got me 2 integrals u*sqrt(25-(u)^2) du + sqrt(25-(u)^2) du
the first integral = (2*pi*24^(3/2))/3
the second i used a trig sub and my final answer is
(25pi^2)/2 +
-25*asin(-.2)+sqrt(24)
3. Answer
the answer is suppose to be 25pi^2 + 500pi/3
i got 25pi^2 + (-75*asin(-.2)+3*sqrt(24)+2*(24)^(3/2) -15)/3
which is approx
25pi^2 + 499.89pi/3
how do i get the exact answer
You are trying to find the volume of a sphere of radius 5 with center at (0, 1, 0)? Projected onto a x, y plane, gives the circle x^2+ (y- 1)^2= 25 and taking only the right half-plane, x= \sqrt{25- (y-1)^2}. That is the figure being rotated around the line y= 1.
And, from the way you are doing this, I take it you are using "cylinders" (I would have been inclined to use disks). Each "cylinder" of radius y has length
\sqrt{25- (y- 1)^2}- (-\sqrt{25- (y-1)^2})= 2\sqrt{25- (y- 1)^2}
and so surface area \pi r^2h= \pi (y- 1)^2(2\sqrt{25- (y-1)^2}). With "thickness" dy, each cylinder will have volume 2\pi (y- 1)^2\sqrt{25- (y-1)^2} dy so the volume of the entire sphere will be the integral, as y goes from 1 to 1+ 5= 6,
2\pi \int_1^6 (y- 1)^2\sqrt{25- (y- 1)^2}dy
A good first step, just as you say, would to be let u= y- 1 so that du= dy, when y= 1, u= 0, when y= 6, u= 5 and the integral becomes
2\pi\int_0^5 u^2\sqrt{25- u^2}du
Yes, you can let u= 5sin(\theta) so that du= 5 cos(\theta)d\theta and \sqrt{25- u^2}= \sqrt{25- 25sin^2(\theta)}= 5\sqrt{cos^2(\theta)}= 5 cos(\theta). Further, when u= 0, 5sin(\theta)= 0 so \theta= 0 and when u= 5, 5 sin(\theta)= 5 so \theta= \pi/2.
The integral becomes
2\pi\int_0^{\pi/2}(25 sin^2(\theta))(5 cos(\theta))(5 cos(\theta))d\theta[/itex]<br /> <br /> I do not know why you are using &quot;y&quot; outside the square root rather than &quot;y- 1&quot; nor do I see why it is not squared. I had to guess at what you really intended since you did not say what the radius or center of the sphere were. I also do not know why you subtracted 5\pi, the &quot;volume of a cylinder&quot; when you said you were finding the volume of a sphere.
no no... sorry the circle is being revolved around the x-axis and y2= 1 which is why so the 5pi exists because i am subtracting the volume from y2
oh and yes amd the question asked me to revolve the circle around the x-axis in terms of y, which is longer by the way.
<br /> 2\pi \int_0^6 y\sqrt{25- (y- 1)^2}dy + 5\pi<br />
that's the integral I want solved and the answer i got is (25pi^2)/2 + (500*pi)/3 intstead of 25pi^2 + 499.89pi/3
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
