Finding Work and Power in a Traffic Junction
  • Thread starter Thread starter herbgriffin
    Power Work
A car weighing 2 tons approaches a traffic junction at 45 km/h and must accelerate to clear the intersection before the light turns red in 6 seconds. The driver needs to calculate the power output of the engine, factoring in a frictional resistance of 0.6 kN per ton. The initial velocity is converted to 12.5 m/s, while the final velocity required to cover 100 meters in the given time is 16.67 m/s. The discussion highlights the need for using kinematic equations to accurately determine acceleration and forces involved, as the initial calculations were incorrect due to not accounting for acceleration. The correct power output calculated is 82.9 kW.
herbgriffin
A car of 2 ton mass traveling at 45 kmph approaches a traffic junction. When the car is 100m before the signal, the driver realizes that the green light is about to turn into red in 6 seconds and hence, he accelerates the car uniformly and crosses just before the light turns red. If the frictional resistance is 0.6 kN/ton, determine the power imparted by the engine at that instant.
Answer: 82.9 kW
P= W/t ; W=Fd
Vi = 45 kmph = 12.5 m/s
V= 100m/6sec =16.67 m/s
and i find the acceleration by the formula of V^2= Vi^2+2ax
and i use the formula of summation of forces horizontal : -Ff + F = ma
Ff= (0.6kN/ton)(2ton) = 1.2kN
and when i find F i substitute it to the formula of power F*100m , but my answer is wrong...please help...
Your calculation for the velocity would be fine if the car was moving at a constant speed. Then, covering 100m in 6 seconds would yield an accurate value for the velocity. In this case, the car has an initial velocity and is accelerating. Do you have another kinematic equation in your repertoire that relates distance covered with initial velocity, acceleration, and time?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
