Finding work given mass and mew?
  • Thread starter Thread starter m4ya
    mass work
To solve the problem of calculating work done while pulling a 200kg sleigh across a level surface with a coefficient of kinetic friction of 0.13, one must first determine the normal force, which is equal to the weight of the sleigh (200kg x 9.8m/s² = 1960N). The frictional force can then be calculated using the formula: frictional force = normal force x coefficient of friction, resulting in 254.8N. Since the sleigh is moving at a constant velocity, the net force is effectively the frictional force, and work done can be calculated using the formula: work = frictional force x distance (254.8N x 94m). It is crucial to note that the normal force does not contribute to the work done because it acts perpendicular to the direction of motion, thus canceling out in terms of work calculation.
m4ya
The problem reads:
"someone is pulling a 200kg sleigh across a field at a constant velocity. If the coefficient of kinetic friction is .13, how much work do they do on the sleigh if they pull it 94 meters?"
I know I have to find force net and then use the formula for work (force x distance)
how would I go about finding force net? Force friction+Force normalizing (which would be mass x gravity?)
any guidance would be helpful asap. thanks!
The way the problem is written you can assume it's a level (horizontal) field.
m4ya said:
The problem reads:
You don't do any work on the normal force. It's perpendicular to the direction of displacement. Think vectors.
Sorry I forgot to mention the problem also states the surface is level, and the sleigh is moving with a constant acceleration. Would I begin by finding force friction and force normalizing?
You'll want the normal force first.
Yes, do that. But then tell me why only the frictional force is important for the work done.
So I multiplied
200kg x 9.8 =1960 (normal force)
1960 x .13 = 254.8 (Force friction)
Would these two be added together to equal force net?
or do I just use the force friction to find the work because the surface is level?
Are you lifting the sled, or dragging it?
pulling, there is no angle. It is a level surface
m4ya said:
So I multiplied
The forces would be added together as vectors. And the equation for the work is the dot product of the force with the displacement. You do know about vectors, right?
so work =force x distance
so 2214 N x 94 m =208,116...
this number seems to big. what am I doing wrong?
isn't it something along the lines of setting the two equal to 0?
You don't add forces pointing in different directions together to get a single number. You have to think about vectors. Each of those forces contributes to the work differently because the work depends on the direction of the force and the direction of the displacement. Not just the magnitude of each.
Yes! Why not include the normal force? Tell me why.
is it because the normal force is acting on the object both up and down? the surface is opposing 1960 N and the object is exerting 1960 N of force on it? so one is positive, one is negative, and they cancel? The i'd get the answer by multiplying the force friction by the distance?
That's actually a pretty good guess. But it isn't quite complete. If a force is acting on an object perpendicular to the direction of motion then no work is done. Work isn't as simple as magnitude of force*magnitude of distance. There are directions to think about. Do you about vectors and dot products?
