Finding x for a spring using energy equations
  • Thread starter Thread starter cbasst
    Energy Spring
To find how far a mass stretches a spring using energy equations, the potential energy of the mass (Ug = mgh) can be set equal to the elastic potential energy of the spring (Us = kx²/2). However, this approach yields the maximum stretch rather than the equilibrium position, where the spring force equals the weight of the mass (mg = kx). The key distinction is that at equilibrium, the mass is not in motion, while the energy method accounts for the mass's kinetic energy as it falls. Understanding this difference clarifies why the energy approach provides a different answer for x compared to the force balance method. The discussion highlights the importance of recognizing the dynamics involved when using energy equations in spring systems.
cbasst
This isn't a homework question, just something I've been thinking about. If given a situation in which mass m is hung on a spring with constant k, I know you can set the spring force equal to the weight of the mass to find how far it stretches. Is there a way to find how far it stretches using energy equations? It seems like it should be doable, but I can't figure out how.
w = mg
F = -kx
ΔUg = mgh
Us = kx2/2
As I said, setting mg = kx can solve for x. How do I do it with energy though?
Ug = Us
mgx = kx2/2
But now I get a different answer for x. What did I do wrong with the energy equations?
The energy approach will give you the farthest the mass on the spring will fall. This is not the equilibrium position. Think about it, if I let the mass drop, then when it passes the equilibrium position, it will not have zero velocity.
Ah. This makes sense now! Thanks!
