First Law of Thermodynamics - Isobaric Cooling
An ideal monatomic gas undergoes an isothermal expansion from 1 L to 2 L at an initial pressure of 3 atm and temperature of 90 degrees Celsius, followed by isobaric cooling. The total work done during these processes is to be calculated using the integral w2→3=∫PdV. The user is uncertain about calculating the new pressure at state 2 using the equation P1V1=P2V2 and is unsure of the final volume after the adiabatic compression back to the initial state. Clarification is needed on how to determine the volume after the cooling phase to complete the work calculation. Understanding these transitions is crucial for accurately applying the First Law of Thermodynamics in this scenario.
chromium1387
An ideal monatomic gas has an initial pressure of 3 atm, an initial volume of 1 L, and is at an initial temperature of 90 degrees Celsius. It first expands isothermically to 2 L and is then cooled isobarically to a point where it is adiabatically compressed to its initial state. Calculate the total work done.
w2→3=∫PdV=P(V2-V1
Alright. I think I pretty much know what to do, but I am still a little confused. So, I've found the work done after the transition from state 1 to state 2. From there, can I calculate the new pressure at state 2 with P1V1=P2V2? And then, once I have my second pressure, this will be the pressure I use in my integral above. However, I do not know the volume the gas will be after the transition to the third state, which is what I need to find the value of the integral, correct? Or am I missing something?
"...where it is adiabatically compressed to its initial state."
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
