First Order Differential Equation
Woolyabyss
Find the general solution to the following differential equation.
dy/dx = 2x( (y^2) + 1)
I got all x terms on one side and all y terms on the otherside
2x dx = 1/( (y^2) + 1`)dy
integrate
x^2 + c = tan(y)
y = tan-inverse(x^2 + c)
Can somebody tell me if this is right ?
my book says the solution is y = tan(x^2 + c)
It's not right. What is
\int \frac{dy}{1+y^2}?
tan-inverse(1/y)
sorry I see where I went wrong now
it should have been x^2 + c = tan-inverse(y)
Woolyabyss said:
tan-inverse(1/y)
∫dy/(1+y2) = tan-1y
So,tan-1y = x2 + c
or , y = tan(x2 + c)
Tanya Sharma said:
∫dy/(1+y2) = tan-1y
So,tan-1y = x2 + c
Could you help me with another one?
Given the differential equation
x(dy/dx) = √(4 - y^2) , find the general solution given that y = 0 when x = 1
I got all the x terms to one side and all of the y terms to the opposite side.
1/√(4 - y^2) dy = 1/x dx
integrating gives
sin-inverse(y/2) = lnx
using the limits and we get
y/2 = sin(lnx)
y = 2sin(lnx)
my book says the solution is y = sin(lnx)
integrating gives
y/2 = sin(lnx)
y = 2sin(lnx)
y=2sin(lnx) looks to be the correct answer.You can verify that by putting the solution in the original equation and checking whether it satisfies the eq.
Note : Even though you came up with the correct answer ,please do not ignore the constant of integration C while integrating.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
