First Order Differential Equations
19 replies · 5K views
Bucky
Solve the following differential equation using separation of variables
[tex](1+x)^2 y' = (1-y)^2 , y(1) = 2[/tex]
haven't gotten very far in this at all :/
i've tried dividing both sides by [tex](1+x)^2[/tex], in order to get y' on it's own..
[tex]y' = \frac{(1-y)^2}{(1+x)^2}[/tex]but i don't know how to integrate this...but had a go anyway
apparently the rule for integrating an expression in brackets is..
[tex]\frac{(ax + b)^n}{a(n+1)}[/tex]
so i tried integrating both halves of the fraction seperatley...giving
[tex] \frac{(-y+1)^3 }{-3y}[/tex]
[tex] \frac{(x+1)^2}{3x}[/tex]
putting these together and dividing gave
[tex]\frac{3x(-y+1)^2}{-3y(x+1)^3} + C[/tex]however i don't think this is accurage, as substituting in 1 and 2 for x and y respectivley gmade C some out as -3/48. Can someone shed some light at where I've went wrong?
You haven't gotten y on it's own. Write y'=dy/dx and put the dy with the y's and the dx with the x's.
are you saying i need to get the y terms on one side of the equals and the x terms on the other side?
if so then I'm stumped. I'm not sure how to split up the equation in it's initial form.
How about dy/(1-y)^2=dx/(1+x)^2? Does it look split now?
ok, right, rearranged it and here's what i have:
[tex]\int \frac{dy}{(1-y)^2} = \frac{dx}{(1+x)^2}[/tex]
[tex]\frac {1}{(1-y)^3}{3} = {1}{(1+x)^3}{3} + C[/tex]
which, after substituting y(0) = -1 (wrong values on first post BTW) i get
[tex]\frac{-7}{24} = C[/tex]
I'm pretty sure this is wrong...but anyway let's sub that back into the integrated function
[tex]\frac{1}{3} (1-y)^3 = \frac{1}{3} (1+x)^3 - 7/24[/tex]
[tex]\frac 8(1-y)^3 = 8(1+x)^3 - 7[/tex]
the answer in the book is given as
[tex]y = \frac{x-1}{1+3x}[/tex]
It would help a lot if you did the integrations correctly. The integral of 1/x^2 is not 1/x^3.
er sorry that's a typo, i get the integral of 1/(1+x)^3 to be...
1/3(1+x)^3
You want to integrate 1/(1+x)^2. Try again.
Hint: integral of 1/u^2 du=-1/u.
so...the integral of 1/(1+x)^2 is just -1 - (1/x) ?
even that doesn't seem right...though my formula book doesn't have the formula for such an instance.
Make a substitution u=x+1. Similarly for the y integral. You have done that, right?
ok so that gives...
[tex]- \frac{1}{(1-y)} = - \frac{1}{(1+x)}[/tex]
[tex]\int \frac{dy}{(1-y)^2} = \int \frac{dx}{(1+x)^2}[/tex]
I added the integral sign on the right side.
I think you meant
[tex]\frac{1}{3(1-y)^3}= \frac{1}{3(1+x)^3}+ C[/tex]
but you've missed a sign. But only one sign. As Dick said you need to substitute for both 1+ x and 1- y. If u= 1- y, what is du?
HallsofIvy said:
I think you meant
I think Halls was just cleaning up your notation and doesn't mean to imply that cube is the right power. But you did miss the substitution sign.
i don't see where the missing sign is. unless the sign attatched to the letter comes out? but that's not what i thought you meant when you said
1/u^2 = -1/u
so do you mean that i should have...
[tex]\frac{dy}{(1-y)^2} = \frac{dx}{(1+x)^2}[/tex]
[tex]-\frac{dy}{(1-y)^2} = \frac{dx}{(1+x)^2}[/tex]
EDIT: wait that can't be right...yeah I'm lost.
Bucky said:
ok so that gives...
If you differentiate the right side of this you get 1/(1+x)^2. That's what you want. If you differentiate the left side you get -1/(1-y)^2. Don't forget the chain rule. That's NOT what you want.
1/u^2 = -1/u
He certainly never said that! he said that the anti-derivative of 1/u2 is -1/u.
If you let u= 1+ x, then du= dx and dx/(1+x)2= du/u2. What's the anti-derivative of that?
If you let v= 1-y, then dv= -dy and y/(1-y)2= -dv/v2. What's the anti-derivative of that?
ok so i tried a totally different method and it seems to work.
instaed of substitution i tried using the standard integral
[tex]\int (ax+b)^n = \frac{(ax+b)^{n+1}}{a(n+1)}[/tex]
thanks a lot for your help guys!
Let u=(ax+b), du=a*dx, du/a=dx.
[tex]\int (ax+b)^n dx= \frac{1}{a} \int (u)^n du = \frac{1}{a}<br /> \frac{u^(n+1)}{(n+1)} = \frac{(ax+b)^{n+1}}{a(n+1)}[/tex]
That is a TOTALLY DIFFERENT METHOD!
[tex]\int (ax+b)^n dx= \frac{1}{a} \int (u)^n du = \frac{1}{a}<br /> \frac{u^{n+1}}{(n+1)} = \frac{(ax+b)^{n+1}}{a(n+1)}[/tex]
