Bobbo Snap
- 29
Suppose we put a delta function bump in the center of the infinite square well:
<br /> H' = \alpha \delta(x -a/2),<br />
where \alpha is constant.
a) Find the first order correction to the allowed energies.
b) Find the first three non-zero terms in the expansion of the correction to the ground state, \psi_1^1.
First order correction to the energy:
E_n^1 = \langle \psi_n^0 | H' | \psi_n^0 \rangle.
First order correction to the wave function:
\psi_n^1 = \sum_{m \neq n} \frac{\langle \psi_m^0 | H' | \psi_n^0 \rangle}{(E_n^0 - E_m^0)}\psi_m^0.
Wavefunction for the infinite square well:
\psi_n(x) = \sqrt{2/a} \sin{\frac{n \pi}{a}x}
Energy for the infinite square well:
E_n = \frac{n^2 \pi^2 \hbar^2}{2ma^2}
I think I got part a right. It worked out to \frac{2 \alpha}{a} for odd n and 0 for even n.
Part b has me a little confused. In the equation for the first order correction to the wavefunction, what am I supposed to sum over? If it is m, then the first three terms are m=3, m=5, m=7 since m is not n and m must be odd. But then I have \langle \psi_3^0 |H'|\psi_1^0\rangle, \langle \psi_5^0 |H'| \psi_1^0 \rangle, \text{ and } \langle \psi_7^0 |H'| \psi_1^0 \rangle in the numerators of the first three terms. But wouldn't orthogonality then make all of these terms zero so there would be no non-zero terms in the expansion? I'm not understanding how to evaluate this sum. Any help would be appreciated.
