What Is the Q-Value of Pu-239 Fission into Sr-92, He-4, and Neutrons?
In summary, the fission reaction of Pu-239 + gamma --> Sr-92 + Ba-147 + 3n releases a Q-value of -2625.8 MeV. This indicates that the reaction is exothermic, meaning energy is released. The atomic numbers of plutonium and strontium are 94 and 38 respectively. The Q-value is calculated by finding the mass difference between the reactants and products and converting it to energy using the formula Q = Δmc2.
says
594
Fission Reaction: Pu-239 + gamma --> Sr-92 + ? + 3n
Q-Value = ? (Answer in MeV, correct to 5 significant figures)
Atomic Masses (u)
Alpha Particle = 4.00150618
He-4 = 4.0026032497
Pu-239 = 239.0521565
Sr-92 = 91.911030
n (neutron) = 1.00866501
Q-Value = Q = E = Δmc2 = (mi - mf)c2
Q = (239.0521565 + gamma) - (91.911030 + 4.0026032497 + (3*1.00866501)) * c2
= (239.0521565 + gamma) - (98.939628)
Q = gamma = -140.1125285 * 931.5020
= -130515.1
= - 130520 MeV (correct to 5 significant figures)
Two Questions
1) I've seen examples where He-4 = 4.0026032497 is used in this calculation instead of the Alpha Particle = 4.00150618. Why is this? I know He-4 is missing it's two electrons, therefore it's mass is the equivalent of the alpha particle, but how come He-4 atomic mass ≠ alpha particle. And why should I use the atomic mass of He-4 in this calculation instead of the atomic mass of the alpha particle?
2) Is Q negative because it represents the amount of energy which must be provided for the reaction to occur? I.e. A gamma ray with 130520 MeV must be provided to split a Pu-239 atom into Sr-92 + He-4 + 3n
I'm a bit confused as to why you've introduced an alpha into your solution? Looking at the problem statement there are only the Pu, gamma, Sr, and 3n.
Pu-239 decays via alpha decay.
so Pu-239 + gamma --> Sr-92 + ? + 3n
If Pu-239 decays via alpha decay then ' ? ' = He-4
Pu-239 + gamma --> Sr-92 + He-4 + 3n
Sorry, that was the first part of the question but I figured that out from a quick google search.
To answer your question on the mass difference between He-4 and an alpha, He-4 has two electrons (which are on the order of 0.0005amu each) and an alpha has none - an alpha is just a He-4 nucleus.
Your Q value should be positive, it is the amount of energy released from the reaction. When I read the question as set up what I see is gamma induced fission of Pu resulting in Sr, 3n, and a lot of energy. The fact that Pu-239 decays via alpha emission doesn't factor in. So what I would set up to solve is ((mass Pu)-(mass Sr + mass 3n))c^2
Sorry, the full question states:
Complete the following fission reaction, and then calculate the Q-value for the reaction: Pu-239 + gamma --> Sr-92 + ? + 3n
I'm pretty sure that means Pu-239 + gamma --> Sr-92 + He-4 + 3n
I thought because the energy of the gamma ray is the only unknown then Q = energy of the gamma ray = 130520 MeV
Because the energy of the gamma ray is the amount of energy that has to be provided for the reaction of Pu-239 + gamma --> Sr-92 + He-4 + 3n to occur, this means gamma = -130520 MeV
The OP indicates gamma-induced fission (as opposed to neutron-induced fission). The ? should be a fission product, not an alpha particle. The sums of Zs and As on the leftside of the equation should equal the sum of the Zs and As. The gamma ray has no charge or mass. Z(Pu) = 94, Z(Sr) = 38. Neutrons have no charge, but atomic mass, A = 1.
Likes atomicpedals
The Q value is a measure of the energy released in a reaction. So in this case it is the energy released in a Pu+gamma reaction (gamma induced fission of Pu). A positive Q value means the reaction is exothermic (which fission very much is), a negative would indicate the reaction was endothermic.
This is why the PF HW forum rules ask posters to include the full question when filling out the HW template. Otherwise, a lot of time is wasted in going back and forth trying to make sense of what is being asked.
Also, the fission reaction:
needs examination. Has anyone tried to balance the left hand side with the right hand side? What's the atomic number of plutonium? Of strontium?
A gamma ray with an energy of 130,000 MeV is an extraordinary event. You only get about 200 MeV from the fission of a single atom of U-235.
Pu-239 ---> Sr-92 + Ba-147 + 3n
Z
Pu = 94
Sr = 38
Ba = 56
Ba-147 = 146.93399 u
Q = E = Δmc2
= (239.0521565 - (91.911030 + 146.93399 + 3.02599503) * c2
= - 2.81886 * 931.5020
= -2625.77
= -2625.8 MeV (correct to 5 significant figures)
I think I've calculated it correctly now. I'm not sure about the negative/positive value. My notes say that 'if Q is negative, it represents the amount of energy which must be provided in order for the reaction to occur.'
Z
Pu = 94
Sr = 38
Ba = 56
Q = E = Δmc2
= -2625.77
Did you add up the atomic masses on both sides of the fission equation?
Closer. However, you appear to have created mass with your fission products.
Left hand side = 91.911030 + 146.93399 + 3.02599503 = 241.8710150
Right hand side = 239.0521565 + gamma
Q = E = Δmc2
= (minitial - mfinal) * c2
(239.0521565 + gamma)*c2 ---> 241.8710150*c2
222,677.5619 - 225,303.3342
= - 2625.77 MeV
= - 2625.8 MeV (correct to 5 significant figures)
Q = E = Δmc2
= - 2625.77 MeV
You only started with on atom of Pu-239, on the left hand side. How did you get "Left hand side = 91.911030 + 146.93399 + 3.02599503 = 241.8710150"?
Sorry, meant to be
right hand side = 91.911030 + 146.93399 + 3.02599503 = 241.8710150
left hand side = 239.0521565 + gamma
Your Q value is still about an order of magnitude too large.
How could this be? I've used the correct units
Q = E = Δmc2
= - 2625.77 MeV
says said:
Sorry, meant to be
The atomic masses must be equal. 239 + 0 (gamma) = 92 + ? + 3.
Likes atomicpedals
Generally, fission reactions are exothermic, greatly so. Why else would you want to build a nuclear plant, if you had to keep shoving all this energy into it to split atoms?
Also, fission reactions involving uranium and plutonium evolve pretty much the same energy per atom:
http://www.kayelaby.npl.co.uk/atomic_and_nuclear_physics/4_7/4_7_1.html
I assumed because this is a question about mass-energy equivalence, q-value / decay energy that the difference between products and reactants is what is needed to be input for the reaction to occur.
mf*c2 does not always equal mi*c2 because of the different binding energies of the product nuclei.
If Q = ∑mfc2 - mic2
(239.0521565)*c2 - 241.8710150*c2
-2.8188585 * 931.5020
= -2625.77 MeV
You will have a mass difference, the sum of the masses of the products will be slightly smaller than that of the Pu. The "missing" mass being accounted for as energy.
The problem you have now is that your proposed fission product Ba results in the mass of the products being greater than the reactants, violating conservation of mass. Is there something on the periodic chart you could use that is slightly lighter than Ba?
I - 144 = 143.94961
So Pu-239 + gamma ---> Sr-92 + I-144 + 3n
Q = (239.0521565 + gamma) - (91.911030 + 143.94961 + (3*1.00866501)) * c2
= (239.0521565 + gamma) - 238.88663503
Q = 0.16552147 * c2
= 154.183580348 MeV
Curious why you chose I-144 instead of Ba-144? Your Q value looks much better. On average fission of Pu-239 releases around 200MeV, so 154MeV is within what one might expect.
Actually,
Atomic Numbers
Pu = 94
Sr = 38
Ba = 56
Mass Numbers
Pu = 239
Sr = 92
Ba = 144
3 * neutrons = 3
Ba-144 = 143.922940
So Pu-239 + gamma ---> Sr-92 + Ba-144 + 3n
Q = (239.0521565 + gamma) - (91.911030 + 143.922940 + (3*1.00866501)) * c2
= (239.0521565 + gamma) - 238.85996503
Q = 0.19219147 * c2
= 179.026738688 MeV
=179.03 MeV (correct to 5 significant figures)
I was getting confused with mass and atomic numbers. I think my post above this is correct though as I used Ba-144.
Looks good to me! You've conserved Z number 38+56=94, and demonstrated energy/mass equivalence while still honoring mass conservation in the process.
Likes says
If you look at the number of isotopes of barium and iodine, you'll see that each element has quite a number of these with a wide range of atomic weights.
http://en.wikipedia.org/wiki/Nuclear_fission#Fission_reactors
Fission reactions can result in varying numbers of neutrons produced to cause other fission reactions, and there is usually two different elements of varying atomic weight created when a uranium or plutonium nucleus is split.
This is why it is important to balance the number of nucleons on both sides of the reaction, just like it is important to balance the two sides of a chemical reaction. :wink:
Likes says
That was confusing me for a while! I was looking at the atomic weights and not the atomic number or mass number. Nice to finally get to the right solution! :smile:
1. What is a fission reaction?
A fission reaction is a type of nuclear reaction in which the nucleus of an atom splits into two or more smaller nuclei, releasing a large amount of energy in the process.
2. What is the Q-value of a fission reaction?
The Q-value of a fission reaction is the difference in energy between the initial state (before the reaction) and the final state (after the reaction). It represents the amount of energy released or absorbed during the reaction.
3. How is the Q-value of a fission reaction calculated?
The Q-value of a fission reaction can be calculated by subtracting the mass of the reactants from the mass of the products and converting the difference into energy using Einstein's famous equation, E=mc^2.
4. What factors affect the Q-value of a fission reaction?
The Q-value of a fission reaction can be affected by various factors, such as the types of nucleons involved in the reaction, the energy of the incoming particles, and the stability of the resulting nuclei.
5. How is the Q-value of a fission reaction related to nuclear power?
The Q-value of a fission reaction is directly related to the amount of energy released during the reaction. In nuclear power plants, controlled fission reactions are used to generate heat, which is then converted into electricity. The higher the Q-value, the more energy can be produced from the reaction, making it an important factor in nuclear power production.
13K
10K
