Floating a cruise ship in a bucket of water
The discussion centers on the theoretical possibility of floating a cruise ship in a small volume of water, such as that contained in a bucket. Participants agree that while it is theoretically feasible, practical challenges arise, including the need for precise measurements and structural integrity of both the ship and the container. Various methods are proposed for demonstrating this concept, such as using a polyethylene film to create a controlled water layer around the ship. The conversation also touches on the importance of buoyancy principles and how to accurately measure displacement and pressure in such a confined setup. Ultimately, the group seeks to establish a practical testing method to validate the theory.
  • #51
votingmachine said:
If you want to buy a ship and try to prove some other thing about tanks and boats ... have at it.
That is the whole point of Mythbusters.
There are widely-held myths out there, some true, some false. The purpose of Mythbusters is to definitively confirm or bust them - based on actual experimentation - not theory.
That is the spirit of this thread.
votingmachine said:
I guess I hold with a position analogous to a Copenhagen-interpretation. I will say the fact I know (the ship displaces 1 million gallons) and if you want to make an unfounded statement about ships and impractical tanks ... I guess I don't care. Build your impractical tank and run the experiment.
Yes. This is where theoreticians pull off the road, and experimentalists put their foot on the gas.
votingmachine said:
This does seem like an angels-on-the-head-of-a-pin debate.
It isn't though. That's the point. It can be done - it can be confirmed or busted.
Some people find theory to be "good enough" or them, and some people prefer definitiveness.
Notice that you already have introduced some confounding effects (eg. surface tension) that suggest you could theorize till the cows come home but never actually know the answer, thus your confidence that it displaces as much as it displaces is already on thin ice.
  • #52
Except the devil is in the detail. And unless everything (Surface finish on boat and tank, definition of "float",etc) is exactly specified, there will not be a definite result. And so we argue angels on a pin.
There is no doubt that somewhere between an ocean of water and a thimble of water is transition and that value depends upon definitions. No need to build a big ark mold, unless you want to open a museum in Kentucky.
I liked mythbusters but I would occasionally be annoyed that at the end of the episode they didn't show why it was silly to do the experiment, because we do know the outcome to near certainty.
Likes russ_watters
  • #53
Also the point of this. As long as all we're doing is talking, there will not be a definite result. Only experimentation will show - first whether it can be done - and second - what the answer is.
No amount of talking will ever confirm that it can't be done.
Engineering will be the solution to fine-tuning specs.
Well that doesn't apply here. Even people in this thread on a Physics forum can't agree on the outcome of this one.
This is a surprisingly tricky concept, a lot of people believe that it can't be done in principle - often surmising something along the lines of "a 10 tonne boat can float in a minimum of 10 tonnes of water. Any less and it will sink." That is false, of course.
  • #54
The fact that some are incorrect does not compel me to build a boat!
You did a good job proscribing the original challenge, but if you can define floating in a reasonable way, and allow stipulations as to support stiffness (and other details) then the answer reguires only application of known Physics. For instance the surface tension of water (which I quoted earlier ) is 72 N per kilometer. That is reason enough to not mention it again
There is no tricky Physics here. Only details and nitpicking. Suppose the boat has a surface (below water) of ##100m^2## then the surface layer made by the bucket of water will be about a tenth of a millimeter thick. So linear thermal expansion per C will be 10 times the clearance.
As a practical matter, the experiment is interesting to contemplate. The result is less so IMHO.
Likes jbriggs444 and Charles Link
  • #55
Science is my thing. My sibs and friends don't intuit engineering, physics and large/small numbers like I do.
They will be skeptical, and nothing will convince them except proof. I like to be the know-it-all.
Likes Charles Link and hutchphd
  • #56
Then do not educate them.
Be the mystic and a storyteller.
Tell the physics like it is a fairytale.
  • Haha
Likes Tom.G, Charles Link and hutchphd
  • #57
With reasonable allowances for a layer of water that is about an inch thick, that experiment could be readily engineered. When that layer gets to be about a millimeter thick, thermal expansion of the boat and/or the tub could start to present difficulties. If you start getting to where the surfaces need to have optical like constraints, that can be very difficult to engineer for sizes that are much bigger than an inch across. In any case, the thread has been very entertaining. Meanwhile, I still think there is a good percentage of the population who would be surprised to find, contrary to Archimedes, (without the qualifier that it is the effective volume displaced), that you can even float a five pound boat with far less than five pounds of water.
Likes hutchphd
  • #58
Is there a simple calculation to turn that into energy per area (ergs per square meter)? I have some confusion on tension when it is a surface energy calculation. I recall that when I would drop a cover-slip onto a microscope slide, it would really pull down. Prying it off with a razor blade required a lot of force. I'm not convinced that the surface energy is an insignificant factor. Especially once the thickness is a very thin capillary thickness.
And of course it matters what the boat surface is. A teflon coated boat is different from a hydrophilic coated boat. And the tank coating matters also. And the water purity matters. A trace amount of surfactant changes everything.
Likes Charles Link
  • #59
The Archimede ‘ s law keeps its validity for a ship even in a narrow dock, with a small gap between side and bottom plating, and the corresponding dock walls and bottom. Also when the ship is navigating in open sea, and one ignores resistance to motion, essentially due to viscous forces and other causes, such as shape-resistance and waves-making forces, it is valid.
But , if one considers particular situations, some problems arise. I’ll explain what i’m referring to. Suppose a ship is to be pulled in a narrow canal, where side and bottom gaps are small, compared with the ship’s breadth and draft. A very simple application of the continuity equation tells us that the water speed, around the ship, must increase; one can carefully equilibrate the forces that pull forward (f.i. exerted by tugs) or by ground ropes. But a problem arises at the bottom, because there is shallow water: a simple thought to the Bernoulli theorem tells that the increase in speed is accompanied by a decrease of pressure. So the bottom of the ship can hit the canal’s bottom very hardly , and this, together with pulling, causes a series of indents and severe damages to the bottom plating.
This isn’t a joke, in the past the problem arised a lot of times, and I’ve repaired many ships, damaged that way.
  • #60
That is an interesting point. But remember that 1 atm is 15 PSI. So the cover slip has 5 pounds of force pushing it down as long as there is a water seal (independent of viscosity and surface tension). The details of that seal do depend upon these and geometric factors. Air must invade the interface. This doesn't affect lateral forces, and it does not really affect buoyancy. It greatly affects attempts to lift objects out of a buoyant state until the seal is breached.
Likes Bystander
  • #61
Yes, I've heard of this. Ships navigating shallow canals ride lower the faster they move.
Likes italicus
  • #62
I think this is also why floats on seaplanes have the characteristic "step" halfway down the length to create turbulence so they will not be pulled down. Down is the wrong direction for an airplane...
Likes italicus
  • #63
So in the case of ships a good provision is to change the trim , if possible, increasing the aft draft and decreasing the fore one. This can be done moving ballast water towards aft.
Of course, everything is to be done “ cum grano salis” ( salt in your brain!)
  • #64
See https://www.physicsforums.com/threa...e-surface-of-water.944587/page-3#post-5977523 post 58 by @haruspex . There will likely, IMO, be some thickness at which the water starts to behave like a water-tight seal, and loses some of its buoyancy properties.
  • #65
Suppose I have a rubber duck in the bathtub. Everyone agrees it is floating. Now I spray a very high tensile strength (no surface tension) coating on the water (assume it is very duck-phillic and seals to ducky). Is ducky, by your definition, still floating? How come?
  • #66
Certainly, if you tried to lift the ship out of its container, it will definitely resist. (Heck, this happens whenever I try to pull the trash bag out of my kitchen trash bin. It takes, like five minutes to come out!)
But how does it follow that that means it's not floating? Just because you can't lift it from its neutrally buoyant position doesn't mean it's stuck there and not floating. The forces keeping it in place are zero when its stationary, but rise rapidly as you attempt to move it, because water has a very tough time flowing into (or out of) the voided space.
  • #67
Likes Charles Link
  • #68
We take a typical cruise ship size, with a length of 202m, width of 28m, and draft of 6.3m (I took the first one from https://www.cruisemapper.com/wiki/753-cruise-ship-sizes-comparison-dimensions-length-weight-draft). Then the surface area of the ship under water is 2 x 6.3 x (202 + 28) + 202 x 28 = 8554 m3 . The volume of a bucket of water we assume to be 20L = 0.02 m3. If we assume the water thickness on all sides of the ship to be the same, then this will give a water layer thickness of 2.3 micrometer. That is, if the bucket follows the shape of the ship to an accuracy of about 1 micrometer, then the ship will be surrounded by water on all sides.
Now, can we call this "floating"? We consider three aspects of that. First of all, afaik, the thickness of a water layer sticking to a steel plate due to adhesion forces, is thicker than 2.3 micrometer. That is, when you remove the bucket, then the water would still cling to the ship on all sides.
Secondly, 2.3 micrometer is less than the diameter of capillary tube. Therefore, the water on the sides of the ship will creep up between the ship and bucket wall, due to capillary forces. That will remove water from the bottom, reducing the thickness of the layer on the bottom. I have not done a calculation on how high the water will go up, and of course that also depends on the shape of the bucket above the "water line".
Thirdly, the cohesion forces of the water would give the thin layer at the bottom extra buoyancy force. I have not done the calculations, but there is a chance that if you remove the walls of the "bucket", but leave its bottom in place, then ship would still "float" on the thin film of water underneath it.
So do we still call this "floating" in the sense that the question asks about? I would say no, but you'll be your own judge.
Likes DaveC426913
  • #69
That's a really insightful analysis.
  • #70
First of all, a surface is expressed in ##m^2## and not ##m^3## .
But I haven’t understood your determination of the wetted surface area (WSA) of the hull . There are some empirical formulas, see f.i. this , page 6 :
1 Evaluation of wetted surface area of commercial ships as ...https://repository.si.edu › bitstream › handle › Mil...
there are others indeed.
Anyway , the point isn’t this. Do you think that the external hull surface is as smooth as a mirror? It isn’t. You cannot speak of a water layer of some micrometers, uniformly distributed on the whole wetted surface. Have you ever examined the hull surface from a distance , say, of 20 cm ? The surface is not uniform at that level you are considering.
Moreover, the Archimede’s principle , which we can define really a “law of nature” , is a matter of global hydrostatics, doesn’t take into consideration molecular forces of adhesion and cohesion forces of water. This law can be summarised in the vector equation :
$$\ vec\ P + \ vec\ S = 0 $$
nothing more.
  • #71
Thanks for pointing out that typo.
I took the simplification that the underside of the ship is simply rectangular. We are talking about an imaginary theoretical exercise anyways, so there is no point in discussing all kinds of practical details. We just need an idea of what order of magnitude we are talking about.
We are talking about an imaginary theoretical exercise anyways, so there is no point in discussing all kinds of practical details. And I stated that the shape of the "bucket" will have to follow the surface of the ship (whatever shape it has) to an accuracy of 1 micrometer.
nothing more.
Fully agree with that, Archimede's principle does not take into consideration molecular forces. And 2.3 micrometer is definitely a scale where molecular forces must be taken into consideration.
Likes Charles Link
  • #72
The vector formula I believe you are referring to above, (the Latex seems to be missing a couple things), with force(s) per unit volume is ## -\nabla P-\delta g \hat{z}=0 ##, for hydrostatic equilibrium. When integrated over a volume, along with a version of Gauss' law for the gradient, the result is Archimedes principle.
  • #73
What keeps a boat afloat? The force of the water pressure on the bottom surface. What is the pressure depend on? The distance from the surface. The height of the surface of the water above the lowest part of the boat. If you come up underneath a floating boat with a container of arbitrary size but large enough to fit the boat and bring the container top edge to the surface of the water the boat remains buoyant and will float in that container. If you continue to raise the container nothing in the container change, the boat is still floating. If the container is made to fit the hull shape to arbitrary close tolerances then the boat can float in a lot less water than it can displace.
A boat float on its waterline no matter how much water is under or around it.
Likes hutchphd and Charles Link
  • #74
absolutely
hutchphd said:
Here's my method:
  • #75
Thank you Charles, I am not able with Latex ! The letter “S” I wrote is the initial of the Italian word “ Spinta” ( push), which stays for the Archimede’s force that makes equilibrium to weight P .
Likes Charles Link
  • #76
Absolutely agreed.
  • #77
I'm using ##P ## for pressure, ## \delta ## for the density of water, and ## g ## for the gravitational constant.
  • #78
I would caution against such a view of Archimedes' Principle.
The buoyancy comes from the integral of the upward component of the fluid's pressure over the surface in contact with the fluid. Archimedes' insight, I assume, is that if we replace the body by more of the fluid occupying the same displacement it would be in equilibrium, so the buoyancy force on that would be equal to its weight.
But note that there is a hidden assumption in equating that to the buoyancy force on the object: that the fluid is able to reach all parts of the body's surface below the surface level of the fluid. For example, the Principle breaks down for a rubber suction cap stuck to the bottom of a tank.
  • #79
Obvious!
Could you explain better your example, please? Maybe I haven’t understood it!
As a marine engineer and naval architect, with 40 years of experience in the field, I’ve always found the buoyancy by ##\rho g V ## , where V is the immersed volume of a floating body, or even a totally submerged body ( think of a submarine for example) , that displaces water.
One moment...do you mean something like this in the sketch?
but it is obvious , the surface of the cup inside the tank is to be considered “part “ of the tank bottom, no component of water pressure on it is directed towards the surface of tha water!
  • #80
You can choose to consider it that way, but if you blindly apply Archimedes' Principle to the cap alone it does not work. Hence the need for caution.
  • #81
Believe me, I have never been so blind...In any case, caution is often useful or even necessary, in all circumstances of science and technology. I agree on that.
  • #82
To expound upon what @haruspex is describing, consider a very flat glass plate that is completely submerged, where it will experience a buoyant force by Archimedes equal to the weight of the water of the same volume as the glass plate. Then consider what occurs if you press it against a very flat bottom as it is submerged in a deep tank. It will be stuck to the bottom with a tremendous pressure from the water above, but, as there is no water underneath it to counter, the buoyant force given by Archimedes simply does not hold for this second case.
Likes hutchphd
  • #83
I would say this a little differently: as there is no possibility of water influx (thereby communicating the external pressure)...
Seems a clearer statement to me and some clarity appears to be required.
Likes Charles Link
  • #84
The difficulty is that Archimedes' Principle is generally expressed as "the buoyant force is equal to the weight of the fluid displaced". I never see it hedged around with any caveat. Your phrasing in post #70 sought to elevate it to a universal law, but in that form it is not.
You might not make the mistake of applying it where it is invalid, but I have seen students do so on this very forum.
  • #85
Keeping post 82 in mind, and looking back on post 64, there will be some thickness (very thin layer) of water ##d ## that we lack data for, where the air pressure on the boat from above will not be countered or transferred to the water below the boat, and for this case we can ask whether the boat is truly floating. This makes it into a somewhat nebulous problem, and it may be beyond the scope of what @DaveC426913 is looking for.
Likes hutchphd
  • #86
Dear haruspex
I am not a student! I have sometimes taught this subject to them, and still consider Archimedes’ principle a law of nature, when free floating bodies are concerned. The rubber cup you have proposed isn’t a free floating body, no?
But a more difficult example which I was used to make is the following: consider a heavy rubber ball, (but lighter than an equal volume of water) , kept under water and tied by a rope to the bottom of a tank at rest on Earth What is the tension in the rope?
  • #87
1. The principle as commonly stated does not specify free-floating
2. In fact, it is not limited to free-floating. It works perfectly well for a body resting on the bottom provided the fluid can reach under it.
3. Ergo, if you wish to teach it well, mention that proviso.
  • #88
I have made an example where the ball is tied by a rope to the bottom of a tank, three forces act on the ball, one of which is Archimedes’ force. But what is your position? Mine is that this principle is a law of nature, Archimede simply discovered it, didn’t invent, when playing with the king’s crown in his bathtube, according to the legend…
If a cubic block of steel rests on the bottom of a pool, a thin layer of water underneath is enough to give a hydrostatic force upwards. But you really know nothing about how many contact points are between the two surfaces, which aren’t as smooth as a mirror, and how many small areas are truly supported by water: you cannot really speak of a uniform water layer, so what are we talking about?
You have to “weld” the block to the bottom, or seal accurately the perimeter of contact to prevent water entering underneath, so that Archimedes’ law isn’t applicable.
If a ship is moored to a berth by means of ropes, one should consider also the forces exerted by the ropes, to determine a correct ship’s weight, but this way takes to incorrect evaluation; better, one has to release ropes and read drafts; but the water level isn’t really stable around a draft mark , you can have excursions of 10 cm or more, due to sea and ship’s motion. So you have to use the famous “grain of salt” , which is another way to mean experience. The mean draft of the ship gives you the displacement, its accuracy is as good as possible, everybody in the shipping world knows that.
But I think we have repeated this concept of Archimedes’ law too many times, nothing more needs to be added.
  • #89
I would judge that in this case, where the water cannot get beneath the object, there is still the same buoyancy force, equal to the weight of the displaced water. But there is an extra downwards force on the object, due to the pressure difference of the water above the object with the near-vacuum beneath the object.
For example, if we measure the force that the object exerts on the floor, then that is still equal to the weight of the object minus the weight of the displaced water. That is, the object still tries to pull the floor up with the buoyancy force. It is just that the floor is able to counteract that force to keep the object down.
  • #90
Be careful. If the water cannot get beneath the object, because the object is “welded” or accurately sealed around the contact perimeter, there is no buoyancy force on the object! That was the first example by Haruspex, the one of the rubber cup in a hole of the bottom tank. No buoyancy force means that the object’s weight is entirely supported by the bottom tank.
No, read above. The floor ( or the tank bottom) doesn’t have to counteract any buoyant force to keep the object down. For clarity, we are speaking of objects heavier than an equal volume of water, which therefore tend to sink when left free.
Instead, consider the example that I have posted in #86 , of a rubber ball tied to the bottom by means of a rope, and evaluate the tension in the rope. There are 3 forces acting on the ball , which are in equilibrium.
Likes Charles Link
  • #91
Yes. In addition, the object can be "plastered" against the bottom by the pressure forces from the above water plus air pressure, acting downward, with no upward force to balance or counter. This happens with a suction cup or even a glass plate, if we pull upwards on it. If we pull the suction cup from the center, (or even the glass plate), we can pull it away from the bottom surface just enough, that the bottom surface is no longer supplying an upward force. There still is no upward buoyancy force, and we find we need to pull very, very hard, before we finally free the suction, and then have an upward buoyancy force. When the upward buoyancy force is absent or reduced, e.g. with the boat, we need to ask whether it is truly floating.
Likes italicus
  • #92
Be that as it may, I am not convinced that this scenario is applicable to the proposed scenario. I think it's a faulty analogy.
  • #93
When you theoretically create a layer of water that is on the order of microns or nanometers in thickness, it is likely, (we seem to lack sufficient data here), that the buoyant forces from underneath will be greatly reduced.
  • #94
If air is all around the tank, above and below, you can refer to relative pressure only, because air pressure above the surface is equal to air pressure below, so they compensate.
Here is an exercise taken from Cengel-Cimbala : Fluid mechanics fundamentals ; a car is at the bottom of a lake...
Likes Charles Link
  • #95
Yes. As I mentioned before there is obviously some scale at which water is no longer a 3D fluid. But the mean free path of a water molecule at STP is few angstroms, so a nanometer is probably the correct scale. This of course assumes that the surface is true to that scale (roughly the precision to which telescope mirrors are ground).
We are discussing angels on a pin. Not a bad question, but I'm out.
Likes Charles Link
  • #96
This is simply restating your claim, and it's a red herring. Whether or not it's true, it isn't necessarily germane to the specific scenario at-hand.
An object that is submerged and stuck to the bottom of a tank is not analogous to an object that is partially emmersed* and neutrally buoyant.
* I am sure this is a word. The internet disagrees. :wideeyed:
  • #97
DaveC426913 said:
emmersed*
It's one "m", emersed, as with emerge.
  • #98
Yeah. That was what I first typed. But PF's spellcheck didn't like that, so I tried variations, which it didn't like either. Tx.
  • #99
Never knew the word emerse ! Yay new word. @DaveC426913 Were you looking for "immerse" ?
  • #100
I think the word is "immersed". :)
14K
