Fluids Physics Question: Calculating Density and Pressure of a Physics Book"
  • Thread starter Thread starter Leo34005
    Fluids Physics
The physics book measures 26.0 cm in height, 22.4 cm in width, and 3.10 cm in thickness, weighing 18 N. The density is calculated to be 1014 kg/m^3 by dividing the mass (1.83 kg) by the volume (0.00180544 m^3). The pressure exerted on a desktop when the book lies face up is 30.9 Pa, derived from the weight divided by the area of the book's base. When balanced on its spine, the pressure calculation should use the height instead of the width, resulting in a different value. Accurate calculations are essential for determining the correct pressure in both orientations.
Leo34005
A physics book has a height of 26.0 cm, a width of 22.4 cm, and a thickness of 3.10 cm.
(a) What is the density of the physics book if it weighs 18 N?
? kg/m3
(b) Find the pressure that the physics book exerts on a desktop when the book lies face up.
? Pa
(c) Find the pressure that the physics book exerts on the surface of a desktop when the book is balanced on its spine.
? Pa
Divide the weight by gravity to get the mass.
18N/9.81 = 1.83 kg.
P = F/A
Convert cm to meters:
(26.0cm)/100 = 0.26
22.4/100 = 0.224
3.10/100 = 0.031
Now divide
1.83/(0.26*0.224*0.031) = 1.83/0.00180544 = 1014 kg/m^3
P = F/A
area of the book = (0.224*0.26) = 0.5824 m^2
18/0.5824 = 30.9 Pa
When balanced on its spine, its width and thickness make up the area
(0.224*0.0310) = 0.006944
18/0.006944 = 2592 Pa
You got the first two right, but I would say that you should use height in the last problem instead of width.
Like i said, I believe my answer is wrong. If someone would double check it.
That's what I'm saying. Your answer is wrong because you used the wrong number in your calculations. All you need to do is use the right one.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
