Calculate Flux & Current at Intersection of Neutron Beams
  • Thread starter Thread starter timman_24
    Current Flux
timman_24
Two monoenergetic neutron beams I1=2*10^10 and I2=1*10^10 intersect at an angle of 30 degrees. Calculate both the flux and current in the region where they intersect.
I lined the first I1 up parallel to the x-axis and tilted I2 30 degrees below I1 to make the calculations easier.
Flux:
I believe flux is the amount of neutrons passing between the left side to the right side across this arbitrary surface area. I took the surface area to span the y-z axis with the flux passing along the x-axis.
To calculate the flux, I simple did:
I1 + I2*cos(30) = 2.866*10^10 n/(cm^2-s)
Current:
I believe the current to be the vector representation of the net flow. For this I did the following:
J(Jx,Jy) = Jx + Jy
Jx= I1 + I2*cos(30)
Jy= I2*sin(30)
J(Jx,Jy) = 2.866*10^10 i +.5*10^10 j
I am not 100% positive if this is the correct way to do this. I get confused sometimes between current and flux.
Any help would be much appreciated!
I guess a lot of people have trouble with flux and current? :-p
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
