Creating an Image 2x Size of Object w/ Convex Lens: Half Focal Length Away
A converging lens creates an image twice the size of the object when the object is placed half a focal length away from the lens. The relationship between object distance (do), image distance (di), and focal length (f) is clarified through the equations -di/do = hi/ho and 1/f = 1/di + 1/do. The confusion arises from interpreting f=2do; it actually indicates that do equals half the focal length, not two focal lengths. Thus, the correct placement of the object is at f/2, not 2f. Understanding this distinction resolves the initial misunderstanding about the object's position relative to the lens.
Gear2d
A converging lens (convex lens) creates an image that is 2 times the size of the object. The object is placed:
-di/do = hi/ho
1/f = 1/di + 1/do
I thought the answer was that the object is place two focal lengths in front of the lens. But the answer says its half a focal length in front of the lens.
I mean: -di/do = hi/ho = 2
-di = 2do
1/f = 1/di + 1/do
= -1/2do + 1/do = 1/2do
f = 2do
Isn't f=2do saying two focal lengths?
-di/do = hi/ho
1/f = 1/di + 1/do
-di = 2do
1/f = 1/di + 1/do
f = 2do
I'm not sure what you mean. If f=10 for example, then d_o=5, so d_o is half the focal length.
So simple, thanks. I guess I just missed an easy answer by thinking too much (or thinking to less).
Thanks again
No.
f=2do is saying do=f/2, or half a focal length.
(do=2f would be saying two focal lengths.)
