Does a Sinc Pulse in Time Domain Resist Intersymbol Interference?
  • Thread starter Thread starter oufa
    Communication
A sinc pulse in the time domain can effectively resist intersymbol interference (ISI) if transmitted through a channel with sufficient bandwidth. The relationship between the sinc pulse and a rectangular pulse in the frequency domain is crucial; if the channel's bandwidth exceeds the rectangular pulse's width, ISI is avoided. The condition for no ISI is met when the summation of shifted sinc functions at the bit rate remains constant. Properly aligning the pulses ensures that the peak of one pulse aligns with the zero crossings of others, preventing interference. Therefore, a sinc pulse can indeed satisfy the condition for no ISI under the right circumstances.
oufa
please can anyone tell me urgently is the sinc pulse in time domain apulse which resist intersymbol interference or not ?
i know that sinc is infinite given in frequency domain but is the condition of no ISI satisfied which is
summation of shifted sincs by the bit rate value must be aconstant value
is this right or not ?
Hey oufa,
I believe you have got something wrong. A sinc in the time domain corresponds to a rectangular pulse in the frequency domain. So if you transmit a sinc pulse in time, into a channel whose bandwidth is larger than the rectangle in the frequency domain, there would be no ISI.
You can think of this as sending the pulses such that the peak of one pulse would reside at the zero of other pulses, causing no ISI, as you said.
Regards,
Mohammed Omar
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
