For Integral and all forum members - semiconductors industries
The semiconductor industry is currently experiencing a pause in the transition from 300mm to 450mm wafers due to economic considerations and the need for new equipment. Manufacturers prefer to continue operating existing plants rather than invest in larger facilities until demand necessitates such a change. The shift to larger wafers offers significant advantages, including a 2.25 times increase in wafer area, which can lead to higher chip production per wafer. However, the overall economic climate is causing companies to delay investments in new technology. As a result, discussions around wafer size changes remain speculative and heavily influenced by market conditions.
iii
Hello Integral and all the forum members,
Before approximate 8 months I read that some big companies begin to invest a lot of money in change the wafer size from 300 millimeters diameter to 450 millimeters diameter, in these days one friend tell me that he hear that all the industries in semiconductors stop all these processes and all the semiconductors industries will stay with wafers that have 300 millimeters diameters, because I am not sure that it is true and I don't understand what happen so I try to find in google some articles that will confirm it or disprove and will give information and details for these two options (confirmation or disprove) like:
1. If it was stop so why the semiconductors industries stop to the research and development to move from 300 millimeters diameter wafers to 450 millimeters diameter wafers?
2. If it was not stop so what are the advantage and disadvantages from moving from 300 millimeters diameter wafers to 450 millimeters diameter wafers?
http://en.wikipedia.org/wiki/Wafer_(electronics)
The issue of wafer size is an economic one. Increasing wafer size requires equipment to be replaced with larger equipment. It is better to keep running the old plant while building another plant. The economy is not strong, so manufacturers are probably waiting until they need to build a new fabrication plant, with new larger equipment. The manufacturers of the larger equipment will also be waiting for demand before building the next generation equipment.
Why bigger wafers? The number of steps and the process time will remain the same, but the number of chips produced will be higher per wafer. 300 to 450 gives 2.25 times the wafer area.
If you are not in the industry then the wafer size is quite irrelevant to you. There will always be rumours about an industry, if you follow 1% of them, you will be wasting your lifetime.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
10K
9K
