Force alongside the inside of a hemispherical bowl
  • Thread starter Thread starter DevinTyler
    Force
DevinTyler
There is a bowl filled with milk with a diameter of 16cm. (The density of milk is 1050 kg/m³). Find the total force alongside the inside of the bowl.
I decided to break this problem up. First of all, its the first time we've dealt with a hemisphere, so I wasn't too sure on how to approach it, but this is what I came up with:
Force on the bottom of the bowl (a constant): Bottom: Density * Gravitational Constant * Volume = 1050*9.8*pi*8².
Now, to find the force on the sides using integration. I decided to take a look at the bowl from a top down perspective, doing so, I get a circle. Now, I can apply integrals to calculate every 'ring' from the inside to the outside of the bowl.
(integral from 0 to 8)
\int2*pi*h * sqrt(64-h²) * 1050 *9.8 dh
I am very unsure if this method would work, but logically...it seems alright with me!
I had a quick look and I would do exactly the same thing :smile:
Thanks, are you sure that the force on the bottom is the right constant? going to the help center, someone said there wouldn't be any force, I just couldn't believe him.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
