Force and Energy Homework: Solving for Weight and Horizontal Force | Physics"
  • Thread starter Thread starter raman911
    Energy Force
The discussion revolves around solving a physics homework problem involving weight and horizontal force. The weight is calculated as 470.4 N using the formula w = mg, where m is mass and g is gravitational acceleration. The horizontal force is computed as 160.88 N using F_x = mg*cos(70), with an emphasis on including units and direction. Participants highlight the importance of noting both magnitude and direction in the final answer. The direction of the force is identified as being along the incline in the direction of displacement.
raman911
http://img505.imageshack.us/img505/5230/123ae2.png​
[/URL]
2. The attempt at a solution
A)
w=mg
w=48kg*9.8N/kg
w=470.4N
B)
F_x = mg*cos(70)
=48kg*9.8N/kg*cos (70)
=160.88
Is that right
help me......
Looks good to me, but don't forget the units, and you need to note the direction of the force as well as the magnitude.
B)
F_x = mg*cos(70)
=160.88N(U)
Is that right
How can i ind magnitude direction?
I think it is along the incline in the direction of displacement.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
