Force and Torque exerted on a dipole system from a point charge
The discussion focuses on calculating the force and torque exerted on a dipole system formed by two charges in a triangle configuration due to a third charge. The net force on the dipole was initially calculated as zero, but the correct magnitude is 1680 N for each charge. The torque exerted on the dipole was calculated using the formula Torque = Force * distance, resulting in an initial value of 33.75 N·m, while the correct value is 22.3 N·m. It is emphasized that the total force on the dipole must consider the individual forces on each charge and their directions. Accurate calculations are crucial for understanding the dynamics of the dipole system.
binbagsss
I have attached a diagram.
s
Three charge are at corners of an triangle. The + and - 5.00*10^-6C charges form a dipole.
a) Find the magnitude and direction of the force exerted on the dipole from the -10*10^-6C charge.
b) For an axis perepndiculat to the line connected the + and - 5.00*10^-6C charges , find the torque exerted on the dipole by the -10*10^-6 C charge, direction and magnitude?
My attempt:
a) The net force = 0.
Its magnitude on both charges = 1125 N, (from Coloumb's law and using r as 2cm.
However the answer is 1680N on both charges respectively.
b) Torque = Force * distance perpendicular to the line of action.
Considering a single charge, the force exerted on it is 1125N, and the distance perpendicular to the line of action 1.5cm.
The net torque will then = 2(1.5*10^-2 * 1125) , as the force acts in opposite directions on both charges, consequently rotating the dipole system in the same way.
T = 33.75N.m
(The correct answer is however 22.3N.m)F
The question is the force exerted on the whole dipole. You have to add the forces exerted on the separate charges, taking their directions into account.
ehild
