Can Non-Conservation of Momentum Be Explained by an Asymmetry of Space?
Momentum conservation is linked to the symmetry of space, suggesting that an asymmetry in space leads to non-conservation of momentum and generates a force. This concept parallels the understanding of gravity, where force can be associated with spatial asymmetry. The example of two pool balls colliding illustrates that while energy can be conserved, momentum may not be, complicating the interpretation of forces in such scenarios. The discussion raises questions about whether non-conservation of momentum can be consistently viewed as a force. Ultimately, the relationship between space asymmetry and force remains a complex and unresolved topic.
azabak
In the same way that momentum is conserved if and only if space is symmetric it can also be said that whenever space turns asymmetric momentum (of each individual particle) will not be conserved generating a force. Thus can we equate force with an asymmetry of space?
Astronomy news on Phys.org
That's what we do with gravity, more or less. I suppose it's possible to do with other forces as well.
It's not clear whether non-conservation of momentum would be experienced as a force.
Imagine two pool balls striking head on, one moving at speed U the other at speed V > U.
If each were to bounce back with the same speed it had before, energy would be conserved but not momentum. Seems to me you could not interpret this as the intervention of a mysterious force in a consistent way.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
