Force Between Two Concentric Solenoids
  • Thread starter Thread starter dgreenheck
    Force
The discussion centers on calculating the magnetic force between two concentric solenoids, where the inner solenoid is influenced by the time-varying current in the outer fixed solenoid. The inner solenoid, which can slide in and out, experiences induced current due to the magnetic field generated by the outer solenoid. Participants explore whether this magnetic force can be calculated analytically or if it requires numerical methods for a solution. The problem can be simplified by considering both solenoids as thin shells, allowing for a clearer understanding of their interaction. Ultimately, the feasibility of calculating the magnetic force between the two solenoids is the primary focus of the discussion.
dgreenheck
Imagine a finite length solenoid with outer radius R1 and inner radius R2. This solenoid has a time-varying current going though it. This solenoid is also fixed so that it cannot move. Now imagine another solenoid, coaxial with the first, with its outer radius equal to R2 such that it can slide in and out of the first solenoid. The ends of this solenoid are connected together and no current is being externally applied to it. The only current going through it is the induced current from the first coil. My question is, would it be possible to calculate the magnetic force on this solenoid? Or is this a problem that would need to be solved numerically?
My question can be simplified so that both solenoids are a thin shell instead of having a finite thickness. I'm just wondering how one solenoid within another reacts.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
