Force in Center of Mass frame equaling zero
In the discussion about forces in the center of mass (CM) frame, it is established that while the total momentum of two masses in freefall is zero in the CM frame, the application of Newton's second law (F = dP/dt) is only valid in inertial frames. Since the CM frame is accelerating due to gravity, it is not an inertial frame, leading to a contradiction when calculating forces. To resolve this, a fictitious force must be introduced to account for the acceleration of the CM frame. The net forces acting on the masses, including this fictitious force, ultimately balance out to zero, confirming that Fcmf = 0 is valid when properly accounting for all forces.
CGandC
Suppose I have particles with masses m1 and m2 , both are in freefall:
Then , looking at the center of mass coordinates , I know that the sum of momentums of masses m1 and m2 in the center of mass coordinates is equal to zero : P1c + P2c = 0
so now I know that the total force acting on the masses in the center of mass frame is :
Fcmf = d(P1c + P2c )/dt = 0
From here I get : Fcmf = 0
But , If I sum the forces ( only weights ) of the two bodies, I don't get zero : Fcmf= -M2g -M1g ≠ 0
(I get contradiction , because I know as a fact that Fcmf must be equal to zero , Fcmf = 0 )
Why do I get a contradiction?
F = ma
[/B]
CGandC said:
P1c + P2c = 0
This is true only if the CM does not accelerate, i.e. if there are no external forces acting on it. Here there is gravity.
so what will be the sum of momentums P1c + P2c if there are external forces acting on the system? I always get that P1c + P2c = 0 , regardless of whether there are external forces acting on the system or not.
This isn't correct .
OP is right that the net momentum of the two masses in CM frame is zero .
Total momentum of the system is always zero in CM frame irrespective of whether CM is accelerating or not .
Likes CGandC
You are right :smile:
F = dP/dt is valid only in inertial (non accelerating) frames .
Since CM is accelerating , it is not an inertial frame .
You are right when you say that ΣP = 0 in CM frame . But you are wrong if you apply F=dP/dt in CM frame .
Note that F=dP/dt is nothing but Newton's 2nd Law which is valid only in inertial frames .
Hope that helps .
Likes CGandC
You are correct. I meant to say what you said much more eloquently in post #5.
Likes conscience
Hope that helps .
Just to make sure,
If I were to use Newton's second law for the CM accelerating frame , I'd have to fix it like this ( written below ) ? :
F+Ffict=dP/dt , where Ffict is a pseudo-force / fictional force
and This pseudo force is equal to : Ffict = +M1g +M2g , so that F+Fict = 0 , Is this correct?
CGandC said:
Just to make sure,
I am not sure if you are properly applying the fictitious force .
This is what is happening in your example .
Fictitious force acts on all the particles whose motion we are interested in as seen from the accelerated frame .
In your example , fictitious force acts on both ##M_1## and ##M_2## in the direction opposite to the acceleration of the frame (CM frame in your example) .
So , considering downward positive , as seen from the CM frame , fictitious force ##-M_1a_{cm}## acts on ##M_1## apart from ##M_1g## .Similarly fictitious force ##-M_2a_{cm}## acts on ##M_2## apart from ##M_2g## .
##a_{cm}=g##
The net force acting on ##M_1##and ##M_2## as seen from the CM frame = ##-M_1a_{cm} - M_2a_{cm} +M_1g+M_2g ## . This evaluates to 0 .
Likes CGandC
