Force of friction on a curved road
The discussion focuses on calculating the total friction force exerted by the road on a car as it travels along a curved road, specifically at points B and C. It explores the relationship between linear and angular acceleration, using kinematic equations to derive the velocity at point B and the necessary friction forces. The conversation also addresses the minimum coefficient of static friction required for the car to navigate the turn at point B safely. Participants are encouraged to consider both tangential and normal components of friction when analyzing the forces involved. The overall goal is to accurately compute the friction forces at various points during the car's deceleration and turning.
stunner5000pt
The mass m car is traveling at v on the straight portion of the road and then its speed is uniformly reduced from A to C, which point it comes to rest. Compute the magnitude and direction of the total friction force F exerted by the road on the car (a) just before it passes point B, (b)
just after it passes point B and (c) just before it stops at point C. (d) What is the minimum
coefficient of static friction required between the tires and the road for the car to be able to complete the turn at B?
2. The attempt at a solution
Part a - the force of friction as it approaches B
I thought about doing this in two steps:
If we assume that the force of friction is F_{f} then the linear acceleration in the straight part is a = \frac{F_{f}}{m}
so we can use a kinematic formula to determine the velocity at point B
v_{B}^2 = v^2 + 2a d
then
v_{B}^2 = v^2 - \frac{2 F_{f}}{m}
now for the curved section, assuming the road has radius R, the force stays constant, then we can say that the linear acceleration is the same as above. then the angular acceleration is \alpha = \frac{-F_{f}}{mr}
then we can use the rotational version of the above kinematic formula. the velocity at c is zero
0 = \omega_{B}^2 + 2 \left( \frac{-F_{f}}{mr} \right) \left( \frac{\pi}{6} \right)
we can solve for Vb from the above equation
v_{B} = \frac{\pi F_{f}}{3mr^3}
and then we can substitute the equation just derived into the other expression for vb found above. But is this correct?
What about the curved section? IN the curved section, does the sum of the components of friction (caused by the tangential and normal components) the same as the friction we just calculated? In that case, isn't the answer for b and c the same?
Thanks for your help and input!
  1. Find the distance AC (as if it was a straight path);
  2. With your first equation of motion, find the acceleration between AC;
  3. You can then find the (constant) braking force, i.e. the longitudinal component of the friction force;
  4. With your first equation of motion, find the velocity at B;
  5. With the velocity at B, you can find the lateral acceleration at that point;
  6. With F=ma, you can then find the lateral friction force;
  7. Add the lateral and longitudinal components at each point (VC ≠ VB) to find the total force. HINT: Forces are vectors.
