Force on a long straight wire help
  • Thread starter Thread starter Lost4468
    Force Wire
The discussion revolves around calculating the force per unit length on a middle wire in a three-wire arrangement with currents flowing in different directions. Initially, there was confusion about the forces canceling out, leading to an assumption of zero overall force. However, it was clarified that while outer wires attract or repel each other, they do not cancel out the force on the middle wire, which experiences an overall force due to its own current. The conversation highlights the importance of understanding induced currents and their effects on the middle wire. Ultimately, it was concluded that the middle wire does experience a force, assuming it has a pre-existing current.
Lost4468
I'm not sure about the force 3 wires have, here's the question.
The question is:
"Calculate the force per unit length experienced by the middle wire in the arrangement shown."
The thing is I've an overall force of 0 because I1 and I3 are in different directions each producing a force of 0.15Nm^-1. Surely that's wrong? I think the middle wire somehow has an effect but I don't know how.
The question is:
Lost, welcome to PF! :smile:
If 2 wires have currents in the same direction, they repel each other (with an equal but opposite force).
If 2 wires have currents in opposite directions, they attract each other.
So they do not cancel - they amplify each other (on the wire in the middle).
However, I get a different value for the force than what you have.
How did you calculate it?
Which formula did you use?
Nevermind I had the calculation wrong, I found an old mark scheme for it and it says that there's no overall force on the middle wire. Thanks.
Weird, since I believe there is an overall force on the middle wire.
they ( any induced currents from the 2 outer wires) would only cancel in the middle wire if there was no initial current flowing in the middle wire.
I have to assume from the diagram that the 2A flowing in the middle wire is a pre-existing current, so as you say there would be an overall force in the middle wire
cuz the induced current flow from external sources would cancel because they are equal and opposite and leave just the initial 2A flowing in the middle wire?
does that sound right ?
Dave
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
