Quiz 1: Testing Your Knowledge of Force & Inertia
The discussion focuses on solving a physics quiz related to force and inertia, specifically addressing the calculation of forces in a diagram. Participants discuss the force of gravity and the need to resolve vectors into components using trigonometry. One user presents their calculations for tension forces T1 and T2, seeking confirmation of their answers. Respondents emphasize the importance of equilibrium conditions and correcting misconceptions about measuring tension in kilograms. The conversation highlights the need for a solid understanding of Newton's laws and vector resolution in solving mechanics problems.
Ab e r z o m
http://physicsed.buffalostate.edu/c...anics/PDF files/4-FP-Inertia/Tests/Quiz 1.pdf
1) I don't know how to do this, but I know there is the force of gravity by the Earth in the force diagram..
2) For this one I got the answer
Fx=7.5N [I did 1/2(15N) which equals 7.5 N]
Fy=13N [I took my x component 7.5N and I did 7.5sqrt3=13N]
Did I solve this problem right??
3) How do you write an equation for this diagram?
Can you tell me if I did the Bonus right?
T1cos(60)=T2
T2sin(60)= 3kg
T1sin(60)=3kg
I divided both sides by sin(60) to make T1 by itself so
T1sin(60)/sin(60)=3.464
SO T1=3.464
I took T1=3.464 and plug it into T1cos(60)=T2
3.464cos(60)=T2
T2=1.232
So I don't know if I got that one right??
My answer is T1=3.464 and T2=1.232
Please help me..I really need this. Thank you!
1) There is also a normal force and a kinetic frictional force.
2) You need to resolve your vector into components using trig.
3) The system seems to be in equilibrium, so
F_{xnet}=0
and
F_{ynet}=0
Start from there and re-think your strategy for the bonus part. For one, tension is a force so you can't measure it in kg...Remember Newton's second law.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
