Force (Thrust) produced by a water pump at hose end
To calculate the thrust produced by a water pump at the end of a hose, the key parameters include the flow rate, hose diameter, and pump head. The thrust can be determined using the formula F = ρ * Q * v, where ρ is the fluid density, Q is the flow rate, and v is the exit velocity of the water. Given the specifications, the velocity can be derived from the flow rate and hose area. The discussion aims to ascertain if the pump can generate enough thrust to lift a 10kg weight, requiring approximately 98N of force. Further calculations and clarifications on parameters may be needed for precise results.
als29192
Hi all,
I have been searching for days (and trying many different formulas) to try and work out the force (thrust) produced by a water pump at the end of a hose (given a perfect frictionless world) and was hoping someone could help...
The following specifications are given:
Fluid: Water (Density = 1000kg/m3)
Inlet/Outlet/Hose diameter: 6cm
Inlet/Outlet/Hose area: 0.028m2
Flow rate of pump: 1000L/m
Pump Head: 25m = 3.5kg/cm2 - Head to Pressure: p(kg/cm2) = 0.1 h(m)
Starting velocity of water: 0m/s
Pump height: 0m
What would be the correct formula to determine the thrust produced by the exiting water, think of the hose exit as a rocket engine exit... Essentially, I'm trying to workout if the following theoretical pump could lift say a 10kg weight off the ground (require around 98N for force).
If you need any more information please let me know!
Thanks,
Adam
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Let there be a person in a not yet optimally designed sled at h meters in height. Let this sled free fall but user can steer by tilting their body weight in the sled or by optimal sled shape design point it in some horizontal direction where it is wanted to go - in any horizontal direction but once picked fixed. How to calculate horizontal distance d achievable as function of height h. Thus what is f(h) = d. Put another way, imagine a helicopter rises to a height h, but then shuts off all...
