Forces involving a pulley sysem.
  • Thread starter Thread starter grouchy
    Forces Pulley
A block of mass 1.05127 kg on a frictionless table is connected by a string to a mass of 3.94644 kg, influenced by Earth's gravity of 9.8 m/s^2. The net external force acting on the system is calculated to be 38.6751 N, which is confirmed as correct. The acceleration of the two masses is determined to be 7.73857 m/s^2, also verified as correct. The tension in the rope between the masses can be calculated using the formula T = m(1)a, clarifying the confusion regarding the magnitude. Understanding these forces is crucial for analyzing pulley systems in physics.
grouchy
A block of mass 1.05127 kg lies on a frictionless table, pulled by another mass 3.94644 kg under the influence of Earth's gravity. The acceleration of gravity is 9.8 m/s^2.
a) What is the magnitude of the net external force F acting on the two mass system connected by the string? got this to be 38.6751 N and its correct
b) Magnitude of the acceleration of the two masses? I got it to be 7.73857 and its correct.
c) Magnitude of the tension of the rope between the two masses?
Not really sure what c) wants...the magnitude part throws me off.
lol, nvm got it. T=m(1)a :)
