Formation of elements under conditions of thermodynamic equilbrium
In summary, the elements were not formed under conditions of thermodynamic equilibrium. Elements which were not formed under these conditions may have instability (due to high equilibrium temperatures) or be the result of a process which doesn't involve neutron capture.
vertices
62
[Sorry about the long post]
I'm doing an essay where I am exploring whether or not elements were, for the most part, formed under conditions of thermodynamic equilibrium. We know that some element clearly aren't (such as Potassium 40 and uranium which decay radioactivly). I've scoured the web but information on this is suprisingly hard to come by! I'm hoping someone can help!
Basically, I am assuming elements were formed by a simple nuclear build up model thus:
[A-1,Z]+neutron--> [A,Z]
where [A,Z] is an element (or isotope) with mass number A and atomic (proton) number Z. This is plausible because there is no colomb barrier for neutrons to pass through, unlike protons.
If elements WERE formed under conditions of thermodynamic equilibrium, we can use simple Maxwell Boltzmann statistics to work out equilbrium temperatures. (The probability of a particle being in a state Ea is simply exp(-Ea/KT) so we can use the relative abundances of isotope pairs to work out a temperature at which both [A-1,Z] AND [A,Z] are at equilibrium:
Equilbrium Temperature=[tex]\frac{-Dc^{2}}{kln([A-1,Z]/[A,Z]}[/tex]
where
D= Mass Difference = M[A,Z] - {M[A-1,z]+M[neutron]}
k is boltzmann's constant
c is speed of light
and where square brakets [..] now represent the concentration, or relative abudance of the isotope in question.
NOW, on calculating equilibrium temperatures for isotope pairs ([A,Z] and [A-1,Z] of all the elements in the periodic table (please see attached file), I get negative temperatures in some instances! Is there a physical explanation for this?
Furthermore, the equilibrium temperatures seem very high (~10^10 to 10^11 kelvins). As far as I am aware, at such temperatures there is plasma - a "cosmic soup", can there be thermodynamic equilbrium under such conditions?
(if you've got this far, thank you!)
bump!
any thoughts would be greatly appreciated!
The explanation is that the formation of elements isn't done under conditions of thermodynamic equilibrium. This reaction [A-1,Z]+neutron--> [A,Z]
doesn't run backwards.
Thanks for your reply kamerling. Why in principle can it not run backwards?
Tricky!
This is what I am thinking:
If elements were formed under conditions of thermodynamic equilibrium, the equilibrium temperatures (*as I have defined it*) for the different elements should show some consistency, right?
HOWEVER some elements were NOT formed under conditions of thermodynamic equilbrium.
For example:
-nuclei created in supernovae explosions, where nuclei are made much faster than the rate of reaction (and hence no equilbrium temperature is established).
-nuclei which decay by radioactivity (eg. potassium 40)
-some elements that were formed by CNO processes as well as H, C, O, Si burning in stars (WERE these "equilibrium processes"? In anycase, they don't involve neutron capture)
when I try excluding nuclei pairs corresponding to these elements, I still get equilibrium
temperatures which still vary somewhat.
To remind you, I need to determine whether or not most elements were formed under conditions of thermodynamic equilbrium. Can anyone suggest how best to proceed?
I advise you to abandon the attempt to connect cosmic abundances to an equilibrium temperature. You CAN connect cosmic abundances to the stability of the various isotopes or to the neutron densities you might find in a star.
I wish I could (it doesn't make sense to me), but this the approach that my tutor suggested.
Can anyone help with the questions I have raised on this thread?
What is thermodynamic equilibrium?
Thermodynamic equilibrium refers to a state in which the properties of a system remain constant over time, without any net flow or change in the system. In this state, all forces and energy within the system are balanced, resulting in a stable and unchanging state.
How does thermodynamic equilibrium relate to the formation of elements?
Under conditions of thermodynamic equilibrium, the formation of elements is controlled by the laws of thermodynamics, which govern the behavior of energy and matter in a system. This means that the formation of elements is a result of the balance between energy and matter within a system, which ultimately determines the chemical composition of the system.
What factors influence the formation of elements under conditions of thermodynamic equilibrium?
The formation of elements is influenced by several factors, including temperature, pressure, and the availability of reactants. These factors determine the energy and matter present in a system, which in turn affects the chemical reactions and processes that lead to the formation of elements.
What is the role of entropy in the formation of elements under conditions of thermodynamic equilibrium?
Entropy is a measure of disorder or randomness in a system. In the formation of elements, entropy plays a crucial role in determining the direction of chemical reactions. In a system at thermodynamic equilibrium, the overall entropy remains constant or increases, which affects the formation of elements and their distribution within the system.
How does the concept of free energy relate to the formation of elements under conditions of thermodynamic equilibrium?
Free energy is a measure of the amount of energy available to do work in a system. In the formation of elements, free energy determines the stability and spontaneity of chemical reactions. At thermodynamic equilibrium, the free energy is at its minimum, indicating that the system has reached a stable state with the lowest possible energy and maximum stability.
  • High Energy, Nuclear, Particle Physics
  • Thermodynamics
  • Linear and Abstract Algebra
