Formula for calculating the wavelength of sound in interference
The discussion centers on the formula for calculating the wavelength of sound in interference patterns, specifically using the equation ƛ = 2D, where ƛ represents the wavelength in centimeters and D is the average distance between nodes or antinodes. The participants analyze experimental data at different frequencies (500 Hz and 1000 Hz) and discuss the implications of phase differences in sound waves from multiple sources. Key concepts include constructive and destructive interference, the significance of static nodes, and the need for a deeper understanding of wave behavior in interference scenarios.
  • Understanding of sound wave properties and behavior
  • Familiarity with interference patterns in physics
  • Knowledge of basic trigonometric functions and phase shifts
  • Experience with experimental data analysis in physics
  • Research the concept of phase shift in wave mechanics
  • Learn about constructive and destructive interference in sound waves
  • Study the mathematical derivation of wave equations in interference
  • Explore practical applications of sound wave interference in acoustics
Students studying physics, particularly those focusing on wave mechanics and sound interference, as well as educators seeking to enhance their teaching methods in these topics.
HelpMeWithPhysics
We performed an experiment where 2 speakers were set up with 3 chalk lines spaced 1 metre apart from each other in front of the speakers. A 500 hz and then a 1000 hz sound was played through both speakers. We were to walk along the lines and mark the position of where the sound was the quietest (node) for both frequencies. After that we had to measure the distance between these nodes and calculate the wavelength.
For theoretical wavelength: lambda=340m/s divided by frequency
For experimental wavelength I used: lambda=2*distance between nodes
The values calculated was nowhere near the theoretical values, though I guessed they won't be as the results recorded was incredibly inaccurate. My teacher acknowledged the fact the final values won't be close to the theoretical ones but also said that my formula was wrong, that it works to find wavelength of the first line and not the other 2. I need help finding what formula to use, I have searched everyone but I don't really know what I'm looking for and our teacher said that it's not in the textbook that we use.
Here is a diagram of experiment:
Here is the results:
Average distance between nodes (cm)
Frequency (hz)Line 1Line 2Line 3
500253176105
1000333438None
My analysis:
ƛ/2=D
∴ƛ=2D where ƛ=wavelength (cm)
D=distance between nodes/antinodes (the average,cm)
500hz:
Line 1: 506cm
2: 356cm
3: 210
100hz:
Line 1: 666cm
2: 876cm
3: none
As seen above the wavelengths are not same for the different lines, that's because I used the same formula. My guess is that there should be a third value in the equation, eg 'n' where n might equal number of lines/harmonics or whatever. But I'm not sure.
Any help would be appreciated relating to the formula. I need the formula of lambda when the waves are in the same direction.
HelpMeWithPhysics said:
ƛ/2=D
That's not what D means in the formula you quote. For interference, what is the relevant distance?
Is the relevant distance between the two speakers?
No.
Why does interference occur?
haruspex said:
No.
Due to sound waves overlapping. You will get constructive and destructive interference.
Yes, but what is happening at a static node? Why is it always destructive at that point? Think about phase.
I'm going to need some more help, I'm in yr10 and am struggling with finding the correct formula. Also what is a static node? And what do you mean by phase? Thanks
A node that is at a constant location.
If you draw a graph y=sin(x) then shift it sideways a bit you are changing its phase. E.g. it becomes y=sin(x+φ), φ being the phase shift.
If the distance from a source to a listener is not a whole number of wavelengths then, at a given instant, the listener is receiving the signal at a different phase from that at which it is being emitted.
If a signal from one source can take two paths to a listener, and the difference in the path lengths is not a whole number of wavelengths then the listener receives the signal at two different phases. This will cause the signal to be partly or wholly cancelled. That is interference. If mostly canceled then destructive interference; if in phase or nearly so then constructive interference.
In the present case you have two loudspeakers, but you can assume they emit in phase, so effectively a single source, but with different path lengths to the listener.
But really this is all stuff you should have been taught if you are being posed this question.
I agree with you, i should have been taught this by our physics teacher before hand. The problem is when my physics teacher doesn't go over anything. This whole class is confused and she refuses to help. So I have to use other methods of finding out what do to. Hence y I'm on this page. U have been more useful then 7 weeks of my physics teacher.
I'll go over what u said before and let u know if I need anymore help. Thanks
is this it
Length = (Velocity ÷ Frequency) ÷ 2
Wavelength = 2 x length
is this it
No.
Suppose that at some instant the waves generated from one source have displacement (pressure, say) A sin(kx) at any point which is distance x from that source. You can visualise this as waves forming concentric rings around the source, yes?
If the wavelength is λ then points at distances x and x+λ have the same phase at any given instant. (They won't have quite the same displacement since the waves get a bit smaller as we get further from the source.)
So sin(kx)=sin(k(x+λ)), whence kx+2π=k(x+λ), 2π=kλ, k=2π/λ. So we have displacement A sin(2πx/λ) at the point.
Now consider the same point in relation to the other source. If its distance from that source is x', what is the displacement of the wave from this second source at the point? What do the two displacements add up to?
  • · Replies 19 ·
