Formula for calculating w0 (w at resonance)
  • Thread starter Thread starter toxique
    Formula Resonance
The discussion focuses on calculating the resonant frequency (ω0) and inductance (L) in a two-branch parallel circuit consisting of resistors, an inductor, and a capacitor. Participants clarify that at resonance, the circuit behaves like a pure resistive circuit, where the inductive and capacitive impedances are equal. The key formula for calculating L is derived as L = 1/(ω^2 * C), with given values leading to L = 2 mH. There is confusion regarding the total impedance and its reactive component, emphasizing the need for accurate calculations of admittance for each branch. The conversation highlights the complexity of parallel resonance compared to series resonance.
toxique
Hi dudes. sory if it is not the correct area for this question.
A question. What is the formula for calculaing w0 (w at resonance) in a two-branch parallel circuit consisting of:
A voltage source
branch 1: R1 + L (in series)
branch 2: R2 + C (in series)
I thought it was the same as RLC series, but it actually is pretty different.
BTW I got a parallel resonance exercise but cannot figure out how to solve it.
Same circuit as above, but:
r1 = 2 ohm
r2 = 5 ohm
C = -10j ohm
W = 5000 radian
Find out the value of L (both in ohms and Henry)
Any help on this subject is really appreciated.
  1. Calculate the impedance Z_1(\omega) of branch 1.
  2. Calculate the impedance Z_2(\omega) of branch 2.
  3. Calculate the impedance Z(\omega) = X (\omega)+ iY(\omega) of the two parallel branches.
  4. The resonant frequency \omega_0 is that which makes null the imaginary term Y(\omega)
Thanks SGT for your prompt reply.
By Y(w) you mean the reactive component or admitance?
somewhere I've read that for this kind of circuits:
w0 = [ 1 / sqrt(LC) ] * [ sqrt(r^2 - L/C) ] / [ sqrt(r^2 + L/C) ] or something similar. This is what i do not understand.
sorry for not posting in Latex!
at resonance the circuit will act as pure resistive circuits, meaning the power factor is zero or the value of capacitive and inductive impedance is the same. thus:
given:
W= 5000 radians
then:
ZL=WL...impdedance (Z) of inductive element
ZC= 1/WC...impedance (Z) of capacitive element
since ZL=ZC (at resonance)
then:
WL= 1/WC or
L= 1/(W^2*C)
given, W=5000 rad, C=-j10
C= -j10= -j/(WC)
C= 20x10 exp (-6) or 20 microfarad
therefore:
L= 1/ {[5000^2]*[20 x 10 exp (-6)] }
L= 2 x 10 exp (-3) or 2 mili Henry
or, ZL= WL= [5000]*[2 x 10 exp (-3)]
ZL= 10 ohms,,,,thats it
given:
W= 5000 radians
then:
condition: ZL=ZC (at resonance)
then:
WL= 1/WC or L= 1/ (W^2*C)...this is the key formula
C= -j10= -j/(WC)
therefore:
or, ZL= jWL= [5000]*[2 x 10 exp (-3)]
ZL= j10 ohms,,,,thats it
answers:
L= 2 MILIHENRY
ZL= j10 ohms at an angular frequency of 5000
...at resonance
:smile:
Y(\omega) is the reactive component.
Using the set of rules I suggested you, we can conclude that \omega_0 = \frac{1}{\sqrt{LC}} exactly like in a series or parallel circuit.
Thanx a lot guys for your replys.
About the solution by "young e.", a question:
From the results you obtained, it means that Ztotal = 15.43 + 4.2857i.
should not the reactive component on Ztotal be equal to 0, thus leaving only a resistive part <> 0 ? Even working it out as admittances, Y1L and Y2C are different.
y1 = 0.019231 - 0.096154i
y2 = 0.040000 + 0.080000i
y1 + y2 = 0.059231 - 0.016154i
Whats wrong here? I do not get it. AFIK, parallel resonance has a rather ****ty behaviour compared to series resonance.
Best regarss.
Best regarss.
The imaginary part of the admittance is frequency dependent. What frequency have you used to calculate it?
Hi SGT.
I have used W = 5000 (which is 2*pi*796.178) as stated in the excercise. It supposed to be W0 = 5000
Best Regardz.
Forget my previous post. \omega_0 is not \frac{1}{\sqrt{LC}}. Use the rules I suggested you to obtain the resonant frequency.
If you want only to calculate the inductance, the admittance of branch 1 is:
Y_1(\omega)=\frac{1}{R_1 + j\omega L}
The imaginary part of this admittance must be equal to the negative of the admittance of branch 1.
imag(Y_1) = - 0.08
From this you get a second degree equation in L.
