Formula to calculate psi required to deliver gpm through nozzel
  • Thread starter Thread starter SALTYFRIES
    Formula Psi
To calculate the required PSI to deliver 2.5 GPM through a 2mm nozzle, understanding fluid mechanics is essential. The mass flow rate can be determined using the fluid's velocity, cross-sectional area, and density. A practical experiment with a garden hose showed insufficient flow, prompting the idea of using a pressure tank with compressed air to increase pressure. However, the exact PSI needed remains unclear without further calculations. Resources like orifice flow calculators can provide guidance on determining the necessary pressure for the desired water flow.
SALTYFRIES
I need to build a device to test the water resistance of a piece of restaurant equipment. The device must deliver 2.5 GPM of water through a nozzel with an opening of 2mm. Can someone please give me a formula to calculate the required PSI to deliver the needed volume of water?
Thank you.
The answer to that question largely depends on the configuration of your set up. How much experience do you have with fluid mechanics? For starters, the mass flow (your GPS) is equal to the velocity of the fluid times the cross sectional area of the pipe times the fluid density.
I am mostly mechanical and have almost no experience with fluid mechanics. I experimented with 3/4 diameter garden hose, connected to the city water supply, on the end of which was a cap with a drilled 2mm hole. I currently have no practical method to check the pressure of the supply but it delivered 91oz of water per minute, much less than the 320 required. I then had the idea to fill a pressure tank with water and connect compressed air to the tank to increase the pressure, but I do not know how to calculate how many psi would be required and so can't determine if that might be a feasible solution.
