Formulas and reasoning behind finding focal length
The discussion centers on the formulas and reasoning for calculating focal length and radius of curvature in optics. The lens maker's equation is highlighted as a key formula for determining focal length, which relates the focal length to the radii of curvature of the lens surfaces and the refractive index of the lens material. A recommended resource is provided, featuring a Java applet tutorial that may aid in understanding these concepts. Users are encouraged to search for additional sites that explain the lens maker's equation and related optical principles. Understanding these formulas is essential for anyone studying optics.
Apoxyus
hey can someone give me the formulas and resoning behind finding focal length, magnitude of radius curvature, and other optic stuff. Thank you.
Thanks
