Comp Sci FORTRAN: second-order ODE with Euler Method
The discussion focuses on a Fortran program designed to solve a second-order ordinary differential equation (ODE) using the Euler method, specifically for a particle falling under gravity with air resistance. The user reports issues with their implementation, resulting in incorrect outputs. Key problems identified include improperly defined DO loops that lack final values for the loop control variable, which prevents the program from executing correctly. Suggestions for corrections emphasize the need to specify loop limits and ensure proper initialization of variables. The conversation highlights the importance of accurate coding practices in numerical methods for solving differential equations.
Cecily
Dear all, please help. I have tried this question and came up with strange numbers, my fortran is definitely not correct. Please help!
When the effect of the air resistance is taken into account, the equation of motion for a particle of mass
m falling vertically in a gravitational field is given by
m*y''= -m*g - b*v (*)
where g is the gravitational acceleration and v = dy/dt is the velocity. The coefficient b specifies the strength of the interaction between the air and the particle. The initial conditions are y(0) = 1000 m and v(0) = 0 ms-2. Take m = 1 kg and g = 9.8 ms-2 in the following.Write a Fortran program that uses the Euler method to solve the initial value problem.
Consider the case without air resistance b = 0. Plot y(t) against t until y = 0 (i.e., the particle has
reached the ground) for two different time steps Δt = 1 s and 0.01 s in one figure. Plot also the
exact solution in the same figure for comparison.
here is my definitely wrong program...
PROGRAM lab5a
IMPLICIT NONE
INTEGER :: i
REAL :: dt, y_0, v_0, f
REAL, DIMENSION(200) :: y, v, t
REAL, PARAMETER :: epsilon = 1D-6
y(1) = y_0
v(1) = v_0
dt = 1.D0
DO i=2
y(i) = y(1) + v(i-1)*dt
v(i) = v(i-1) + dt*f(y(i-1), v(i-1))
t(i) = t(i-1) + dt
WRITE (10, *) t(i), y(i)
IF (y(i) < epsilon) exit
END DO
dt = 1D-2
DO i=1
t(i) = t(i-1) + dt
WRITE (11, *) t(i), y(i)
END DO
END PROGRAM lab5a
REAL FUNCTION f(y, v)
IMPLICIT NONE
REAL :: y, v
REAL :: m=1, g=9.8, b=0
f = -g - b / m * v
END FUNCTION
PROGRAM lab5a
IMPLICIT NONE
INTEGER :: i
y(1) = y_0
v(1) = v_0
dt = 1.D0
DO i=2
t(i) = t(i-1) + dt
END DO
dt = 1D-2
DO i=1
t(i) = t(i-1) + dt
END DO
END PROGRAM lab5a
IMPLICIT NONE
REAL :: y, v
f = -g - b / m * v
END FUNCTION
Your DO loops are not right. For the first one, you have
DO i=1
END DO
You need to indicate the final value of your loop control variable, like this:
DO i=1 , 10[/color]
END DO
Your other DO loop has the same problem.
