How High and How Long Does a Foul Ball Travel When Hit Straight Up at 22 m/s?
In summary, the ball is hit straight up into the air with a speed of about 22 m/s and it reaches a height of about 4.5 seconds before it comes back down to the ground.
thschica
47
A foul ball is hit straight up into the air with a speed of about 22 m/s.
(a) How high does it go?
? m
(b) How long is it in the air?
? s
How do I solve this
You use basic formulas that you surely already know. The acceleration due to gravity (near the surface of the earth) is -9.1 m/s2.
v(t)= v0- 9.1 t
where v(t) is the velocity of the ball at time t seconds after the ball was hit staight up and v0 is the initial velocity (here 22 m/s).
h(t)= h0+ v0t- 4.95 t2
where h(t) is height of the ball at time t seconds after the ball is hit and h0 is the initial height of the ball. Here you might take it to be 0 although, really, it should be about the shoulder height of the batter- which is not given.
As long as the velocity is positive, the ball is still going up- not yet at its highest point.
When the velocity is negative, the ball is coming back down- already past its highest point.
What do you think the velocity is at the highest point?
Put that into the equation and solve for t to find when the ball is at its highest point. Now use that time in the height equation to find that height.
"How long is it in the air?"
It's in the air until it gets back to the ground! What is its height when it hits the ground? If you put that into the height equation and solve for t what do you get?
Just a small note, HallsofIvy probably meant g = 9.8 m/s² (the 1 probably came from 9.81).
I got the first part. But I am still confused on the second part. I can't find the velocity of the ball at its hightest point.
Nevermind the answer is 4.5 seconds right?
Lay out the BIG FOUR (kinematics equations). There are only 5 variables: acceleration, time, initial velocity, final velocity, and distance. You will have to be given atleast 3 of these 5 variables. Pick out the equation in which there is only 1 unknown and solve.
Vinitial = 22m/s, a= gravity = -9.8m/s/s, Vfinal = 0 m/s (at its peak)
d = ?
How long does it take to get to the ground? Using the conservation of energy the velocity when it reaches the ground again must be equal to when it went up, Vfinal = -22m/s, a = -9.8m/s/s, Vinitial=22m/s, t=?
The answer to what question? :smile:
As far as "I can't find the velocity of the ball at its hightest point." I was trying to give you that: as long as the velocity is positive, the ball is still going up and so is not at its highest point! If the velocity is negative, the ball is now going down and so is past its highest point! The velocity at the highest point can't be positive or negative so it must be 0.
Yes, I meant to write that g= -9.81. Don't know where the "8" got to!
If v(t)= 22- 9.81t= 0, then 9.81t= 22 so t= 22/9.81= 2.24 s when the ball is at its highest point.
Now use h(t)= 22t- 4.91t2 to find the actual height at that time.
Of course the ball ends its flight when h(t)= 0 again. You can solve
22t- 4.91t2= 0 to find the time that happens.
22t- 4.91t2= t(22- 4.91t)= 0 so t= 0 or t= 22/4.91= 4.48 seconds (4.5 to two sig. figures). Of course, because of the symmetry, since we already knew that the ball took 2.24 s to reach its highest point, we could have argued that it will take the same time coming back down: total flight 2.24+ 2.24= 4.48 s.
1. What is the definition of a "foul ball" in baseball?
A "foul ball" in baseball is any ball that is hit by a batter that either lands outside the foul lines or touches any object outside of the playing field before reaching the outfield fence. It is considered a foul ball if it lands on or beyond the first or third base lines, or if it touches any part of the batter's body while the batter is standing outside of the batter's box.
2. How does the height of a foul ball affect its trajectory?
The height of a foul ball can greatly affect its trajectory. A higher ball will have a steeper angle of descent, while a lower ball will have a shallower angle of descent. This means that a higher foul ball will travel a shorter distance before hitting the ground, while a lower foul ball will travel a farther distance before hitting the ground.
3. What factors influence the height of a foul ball?
The height of a foul ball is influenced by several factors, including the initial velocity of the ball, the angle at which it is hit, and the force of gravity. Other factors such as wind and air resistance can also affect the height of a foul ball.
4. How does air resistance affect the height of a foul ball?
Air resistance, also known as drag, can affect the height of a foul ball by slowing down the ball's descent. The higher the air resistance, the slower the ball will fall, resulting in a higher final height. This is why balls hit with a lot of backspin tend to have a higher final height, as the backspin creates a higher air resistance.
5. What is the equation for calculating the height of a foul ball?
The equation for calculating the height of a foul ball is h = v02sin2(α)/2g, where h is the height, v0 is the initial velocity, α is the angle at which the ball was hit, and g is the acceleration due to gravity (9.8 m/s2 on Earth). This equation assumes that air resistance is negligible.
