Fourier Series (differentiation)
driedupfish
sin(t)cos(nt) dt
I tried setting u=sin(t) or cos(nt) or nt but none seems to work. Can someone give me a hint as what to set u equal to? Thanks.
Are you trying to integrate? Over what range?
The function is as follow:
f(t)= 0, -pi ≤ t ≤ 0
sint, 0 ≤ t ≤ pi
≤ (less than or equal to)
I just don't know what to set u equal to, I am thinking of using integration by substitution.
Can someone give me some hints please?
I would start by trying the first few cases by hand n=0, n=1, n=2, n=3, etc.. and see if a pattern develops, both on result and how to evaluate
look at some trig formulas for angle sums & double angle may help before looking at substitution
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
