Fourier Series Involving Hyperbolic Functions
13 replies · 28K views · last reply
aNxello
[SOLVED] Fourier Series Involving Hyperbolic Functions
Hello everyone!
Sorry if this isn't the appropriate board, but I couldn't think of which board would be more appropriate. I was running through some problems I have to do as practice for a test and I got stuck on one I'm 99% sure they'll ask in the test, in some way or another, and I can't figure it out. This isn't homework, and I'm not asking for you guys to do it for me, but I would love some help to get through it!
Anyways, the problem is simple, I have to expand the function f(x) = cosh(ax) where a is a real number, in a Fourier series over the interval (-pi, pi)
I've started to calculate the coefficients, but they don't seem to be able simplify. I found this online but I can't get to the that answer.
Any help/tips? I'd really appreciate it! (Bow)
Ok , I am not home so I will give you a hint , it is better to use
$$\cosh(ax) =\frac{e^{ax}+e^{-ax}}{2}$$ then use integration by parts.
Ahh! Thank you, I had thought of using this, but I didn't know if it worked when x was next to some constant.
Do you think it would be better to first integrate to obtain 1/a Sinh(ax)? I feel like replacing first will make it harder to find some of the coefficients. Anyways I'll try it out and update!
Thanks!
So for the first coefficient I got this
$$a_{0} = \frac{e^{a\pi } - e^{-a\pi }}{\pi a}$$
but for the second one I keep looping while trying to do integration by parts (I keep getting back to the same integral over and over)
Any clue on how to deal with this:
$$a_{n} =\frac{1}{\pi } \int Cosh(ax)Cos(nx)$$
or
$$b_{n} =\frac{1}{\pi } \int Cosh(ax)Sin(nx)$$
Maybe some hint or identity I could use?
Thanks! :)
or
Thanks! :)
$$\cosh(x)=\frac{e^x+e^{-x}}{2}$$
$$\sin(x)=\frac{e^{ix}-e^{-ix}}{2i}$$
$$\cos(x)=\frac{e^{ix}+e^{-ix}}{2}$$
or
Thanks! :)
Successive integrations by part is a tedious job but it permits to solve the integral... $\displaystyle \int \cosh (a x)\ \cos (nx)\ dx = \frac{1}{a}\ \sinh (ax)\ cos (nx) + \frac{n}{a}\ \int \sinh (a x)\ \sin (nx)\ dx = $
$\displaystyle = \frac{1}{a}\ \sinh (ax)\ cos (nx) + \frac{n}{a^{2}}\ \cosh (a x)\ \sin (n x) - \frac{n^{2}}{a^{2}}\ \int \cosh (a x)\ \cos (n x)\ dx$
... so that is...
$\displaystyle \int \cosh (a x)\ \cos (nx)\ dx = \frac{a\ \sinh (ax)\ cos (nx) + n\ \cosh (a x)\ \sin (n x)} {a^{2} + n^{2}}$
The other indefinite integral $\displaystyle \int \sinh (a x)\ \sin (n x)\ dx$ can be solved in similar way... Kind regards $\chi$ $\sigma$
Thank you very much, let me try to finish this, and I'll let you guys know how it goes! (Dance)
Here is the solution :
$$\cosh(ax) = A_0 +\sum^{\infty}_{k=1} A_k \cos(kx) +\sum^{\infty}_{k=1} B_k \sin(kx)$$
By definition we know that :
$$A_0 = \frac{1}{2\pi} \int^{\pi}_{-\pi} f(x) \, dx$$
$$A_k = \frac{1}{\pi} \int^{\pi}_{-\pi} f(x) \cos(kx)\, dx\,\, k\geq 1$$
$$B_k = \frac{1}{\pi} \int^{\pi}_{-\pi} f(x) \sin(kx)\, dx\,\, k\geq 1$$$$A_0 = \frac{1}{2\pi} \int^{\pi}_{-\pi}\,\cosh(ax) dx=\frac{1}{\pi} \int^{\pi}_{0}\,\cosh(ax) dx =\frac{\,\sinh(a\pi)}{a\pi}$$
Here I will use the result by chisigma (no need to expand the hyperbolic func!)$$A_k = \frac{1}{\pi} \int^{\pi}_{-\pi} \cosh(ax) \cos(kx)\, dx = \frac{2}{\pi}\left(\frac{a\ \sinh (ax)\ cos (kx) + k\ \cosh (a x)\ \sin (k x)} {a^{2} + k^{2}}\right)^{\pi}_0$$
$$A_k=\frac{2}{\pi} \left(\frac{a\ \sinh (a\pi)\cos (k\pi)} {a^{2} + k^{2}}\right)= \frac{2a\ (-1)^k \sinh (a\pi)} {\pi (a^{2} + k^{2})}$$$$B_k = \frac{1}{\pi} \int^{\pi}_{-\pi} \cosh(ax) \sin(kx)\, dx=0 $$ odd function
$$\cosh(ax) = \frac{\sinh(a\pi)}{a\pi} + \frac{2a\,\sinh (a\pi)}{\pi}\,\sum^{\infty}_{k=1} \frac{\ (-1)^k \cos(kx)} {a^{2} + k^{2}}$$
Woah! Thank you!
I don't know what to say, you guys have helped me so much!
I changed the title of the thread so it shows that it's solved (that's the right thing to do right?)
I don't know how to thank you, you guys are awesome! (Bow)
I had not realized Cosh(ax)sin(kx) was odd, that helped a lot!
$$B_k = \frac{2}{\pi} \int^{\pi}_{0} \cosh(ax) \sin(kx)\, dx=0 $$ odd function
I think there might be a mistake here. Odd functions do integrate to zero... if the interval is symmetric. You should write your integral with the symmetric intervals with which you're working.
[EDIT] Error fixed.
So do you you mean like this?
$$B_{n} = \frac{1}{\pi }\int_{-\pi }^{\pi} Cosh(ax)sin(nx)$$
Yes, or maybe it's
$$B_{n}= \frac{2}{ \pi} \int_{- \pi}^{ \pi} \cosh(ax) \sin(nx) \, dx?$$
By the way, use backslashes in front of standard mathematical functions like cosh and sin:
Code:
 \cosh(ax) \sin(nx)
is the right way to go. No capitalization necessary (unless you're working in Mathematica).
Ackbach said:
Yes, or maybe it's
Code:
 \cosh(ax) \sin(nx)
I think that 2 on top of the Pi was there because he had changed the range of the integral, so if we put it back to the original range the 2 shouldn't be there...I might be wrong tho
And thanks! I'm new with latex and I was kinda learning as I was going along, I appreciate the tips!
Yes , copy-paste mistake , I edited it :cool:
