MHB Expanding f(x) in a Fourier Series to Prove $\frac{\pi^2}{8}$
The discussion revolves around expanding the function f(x) = x + 1 in a Fourier series to demonstrate that the sum of the series equals π²/8. Participants suggest that the problem lacks clarity due to the absence of a specified interval, proposing instead to consider the function defined piecewise over the interval [-π, π]. The Fourier series expansion leads to coefficients that ultimately simplify to show the desired result. It is noted that using f(x) = |x| + 1 might yield the correct outcome, aligning with the calculations presented. The conversation emphasizes the importance of defining the function appropriately to achieve the intended mathematical proof.
Suvadip
If $$f(x)=x+1$$, expand $$f(x)$$ in Fourier series and hence show that
$$\sum_{n=0}^\infty \frac{1}{(2n-1)^2}=\frac{\pi^2}{8}$$This question was set in an exam. I am in a position to try it if there is some interval say $$[-\pi \quad \pi]$$ or like that.
But there is no interval in the question. Please give me some suggestion how to proceed.
Mathematics news on Phys.org
The problem is, in my opinion, badly defined. A possible improvement consists in the Fourier series expansion of the function... $\displaystyle f(x)= \begin{cases} \pi - x &\text{if}\ 0 < x < \pi\\ \pi + x &\text{if}\ - \pi < x < 0\end{cases}$ (1)
In that case, writing...
$\displaystyle f(x)= \frac{a_{0}}{2} + \sum_{n=1}^{\infty} (a_{n}\ \cos n x + b_{n}\ \sin n x)$ (2)
... we can compute the coeffcients $a_{n}$ [the $b_{n}$ are zero because the function is even...] as follows...
$\displaystyle a_{0} = \frac{2}{\pi} \int_{0}^{\pi} (\pi - x)\ dx = \pi$ (3)$\displaystyle a_{n} = \frac{2}{\pi} \int_{0}^{\pi} (\pi - x)\ \cos n x\ dx = \frac{2}{\pi}\ \frac{\cos n\ \pi -1}{n^{2}}$ (4)
... so that is...
$\displaystyle f(x) = \frac{\pi}{2} + \frac{4}{\pi}\ (\cos x + \frac {\cos 3x}{9} + \frac{\cos 5 x}{25} + ...)$ (5)
Now setting in (5) $x=0 \implies f(x)= \pi$ we obtain with simple steps... $\displaystyle 1 + \frac {1}{9} + \frac{1} {25} + ... = \frac{\pi^{2}}{8}$ (6) Kind regards $\chi$ $\sigma$
Hi suvadip! :)
The idea of the Fourier series is that you limit your domain to [$-\pi,\pi$], and then extend it again while repeating it.
This is a saw tooth wave.
Anyway, for the calculation of the Fourier series you only look at [$-\pi,\pi$].
The resulting series will be equal to the sawtooth wave.However, with f(x)=x+1, you won't get the result that is required.
What you do get is:
$$f(x)=1+\sum \frac {-2 \cdot (-1)^n}{n} \sin nx$$
$$x + 1 = 1 + 2(\sin x - \frac 1 2 \sin 2x + \frac 1 3 \sin 3x - ...)$$
Filling in $x=\frac \pi 2$ leads to another result:
$$1 - \frac 1 3 + \frac 1 5 - ... = \frac \pi 4$$I suspect that the intended function is $f(x)=|x|+1$, which is similar to the function $\chi$ $\sigma$ suggested and yields the same result.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
