Fourier Transform with two functions
kpou
\geq
Find the Fourier Transform of
y = exp(^{}-at)sin(\omega_{}0t) for t ≥ 0
and = 0 for t < 0
Find the amplitudes C(\omega, S(\omega), and energy spectrum \Phi' for \omega > 0 if the term that peaks at negative frequency can be disregarded for pos frequency.
Y(\omega) = C(\omega) - iS(\omega)
\Phi' = C^2(\omega) + iS^2(\omega)
C(\omega)= \int( y(t)cosw(\omegat)dt from -∞ -> ∞
S(\omega)= \int ( y(t)sin(\omegat)dt from -∞ -> ∞
I have page after page of trying to simplify the algebra down with no luck. In my text it writes "y" in the equation with no function of ( t ) or (\omega) for most every other equation I see contains either of those. Is there something different about y?
It looks like I have to take the Fourier of two functions exp(^{}-at) and sin(\omega_{}0t) over t = 0 -> \infty
I try exp(-at)[/itex]sin\omega_{}0tcos(\omegat) using sin(bx)=(exp(ibx)-exp(-ibx)/2i
Am I missing something? Are there any algebraic tricks I may be missing? Thanks !
C(\omega)= \int( y(t)cosw(\omegat)dt from 0 -> ∞ Since y(t) = 0 for negative t
= \int exp(-at)sin(ω0)t)cos(ω0t)dt
= \int exp(-at)[ (1/2i) ( exp(iω0t) - exp(-iω0t) ) (1/2) ( exp(iωt) + exp(-iωt))] dt
In this case, it's much easier to compute Y(\omega) directly and determine C(\omega), S(\omega) as the real and imaginary parts. You will want to use the identity
\sin z = \frac{e^{iz} - e^{-iz}}{2i}.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
